Introduction
Unable to feed your music through your favorite headphones? It might be time to replace your audio jack. Use this guide to replace the audio jack in an iPad Air 2 Wi-Fi.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
Alternatively, make a battery blocker using a playing card and slide it underneath the logic board connector to disconnect the battery.
Remove the following four Phillips screws securing the upper component cable bracket to the tablet.
Two 1.6 mm
Two 1.3 mm
Slide the upper component cable bracket out from under the protective flaps and remove it from the iPad.
Remove the two 1.8 mm Phillips screws securing the bracket covering the audio jack.
6 autres ont terminé cette réparation.
