Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPad Mini 6 Front Camera Replacement
Ce dont vous avez besoin
    1. iPad Mini 6 Front Camera Replacement, Apply tape to a cracked screen: étape 1, image 1 de 3 iPad Mini 6 Front Camera Replacement, Apply tape to a cracked screen: étape 1, image 2 de 3 iPad Mini 6 Front Camera Replacement, Apply tape to a cracked screen: étape 1, image 3 de 3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      Demander à FixBot
      Ajouter un commentaire
    1. iPad Mini 6 Front Camera Replacement, Heat the bottom edge: étape 2, image 1 de 1
      • Completely power off your device before you begin.
      • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Demander à FixBot
    2. iPad Mini 6 Front Camera Replacement, Screen removal information: étape 3, image 1 de 3 iPad Mini 6 Front Camera Replacement, Screen removal information: étape 3, image 2 de 3 iPad Mini 6 Front Camera Replacement, Screen removal information: étape 3, image 3 de 3
      • While you're waiting for the adhesive to loosen, note the following:
      • The areas at the top and bottom of the screen are sensitive to prying.
      • Don't insert a pick more than 3 mm to avoid damaging the screen.
      • There's a long circuit board attached to the screen that sits parallel to the left edge.
      • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
      • The first two images are mirrored for demonstration purposes.
      Demander à FixBot
    3. iPad Mini 6 Front Camera Replacement, Insert an opening pick: étape 4, image 1 de 3 iPad Mini 6 Front Camera Replacement, Insert an opening pick: étape 4, image 2 de 3 iPad Mini 6 Front Camera Replacement, Insert an opening pick: étape 4, image 3 de 3
      • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an opening pick into the gap between the frame and the screen.
      • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Demander à FixBot
    4. iPad Mini 6 Front Camera Replacement, Separate the bottom adhesive: étape 5, image 1 de 3 iPad Mini 6 Front Camera Replacement, Separate the bottom adhesive: étape 5, image 2 de 3 iPad Mini 6 Front Camera Replacement, Separate the bottom adhesive: étape 5, image 3 de 3
      • Slide the pick along the bottom edge of the device towards the bottom-right corner.
      • Leave the pick in to prevent the adhesive from resealing.
      Demander à FixBot
    5. iPad Mini 6 Front Camera Replacement, Heat the right edge: étape 6, image 1 de 1
      • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
      Demander à FixBot
    6. iPad Mini 6 Front Camera Replacement, Separate the bottom-right corner adhesive: étape 7, image 1 de 3 iPad Mini 6 Front Camera Replacement, Separate the bottom-right corner adhesive: étape 7, image 2 de 3 iPad Mini 6 Front Camera Replacement, Separate the bottom-right corner adhesive: étape 7, image 3 de 3
      • Rotate the opening pick around the bottom-right corner of the device.
      Demander à FixBot
    7. iPad Mini 6 Front Camera Replacement, Separate the remaining adhesive: étape 8, image 1 de 2 iPad Mini 6 Front Camera Replacement, Separate the remaining adhesive: étape 8, image 2 de 2
      • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
      • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
      Demander à FixBot
    8. iPad Mini 6 Front Camera Replacement, Reposition the screen: étape 9, image 1 de 3 iPad Mini 6 Front Camera Replacement, Reposition the screen: étape 9, image 2 de 3 iPad Mini 6 Front Camera Replacement, Reposition the screen: étape 9, image 3 de 3
      • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
      • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
      • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
      • Rest the screen upside down and parallel to the frame before continuing.
      • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
      Demander à FixBot
    9. iPad Mini 6 Front Camera Replacement, Unfasten the display cable bracket: étape 10, image 1 de 2 iPad Mini 6 Front Camera Replacement, Unfasten the display cable bracket: étape 10, image 2 de 2
      • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
      Demander à FixBot
    10. iPad Mini 6 Front Camera Replacement, Remove the display cable bracket: étape 11, image 1 de 2 iPad Mini 6 Front Camera Replacement, Remove the display cable bracket: étape 11, image 2 de 2
      Outil utilisé dans cette étape :
      • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
      Demander à FixBot
    11. iPad Mini 6 Front Camera Replacement, Disconnect the display: étape 12, image 1 de 3 iPad Mini 6 Front Camera Replacement, Disconnect the display: étape 12, image 2 de 3 iPad Mini 6 Front Camera Replacement, Disconnect the display: étape 12, image 3 de 3
      • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
      Demander à FixBot
    12. iPad Mini 6 Front Camera Replacement, Remove the screen: étape 13, image 1 de 2 iPad Mini 6 Front Camera Replacement, Remove the screen: étape 13, image 2 de 2
      • Remove the screen from the frame.
      Demander à FixBot
    1. iPad Mini 6 Front Camera Replacement, Disconnect the battery: étape 14, image 1 de 2 iPad Mini 6 Front Camera Replacement, Disconnect the battery: étape 14, image 2 de 2
      • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Demander à FixBot
    1. iPad Mini 6 Front Camera Replacement, Unfasten the front camera shield: étape 15, image 1 de 2 iPad Mini 6 Front Camera Replacement, Unfasten the front camera shield: étape 15, image 2 de 2
      • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
      Demander à FixBot
    2. iPad Mini 6 Front Camera Replacement, Disconnect the volume button board: étape 16, image 1 de 2 iPad Mini 6 Front Camera Replacement, Disconnect the volume button board: étape 16, image 2 de 2
      • Use the tip of a spudger to pry up and disconnect the volume button board's coaxial cable.
      • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
      Demander à FixBot
    3. iPad Mini 6 Front Camera Replacement, Unfasten the volume button board's coaxial cable: étape 17, image 1 de 2 iPad Mini 6 Front Camera Replacement, Unfasten the volume button board's coaxial cable: étape 17, image 2 de 2
      • Use a Phillips #000 screwdriver to remove the 1 mm screw securing the volume button board's coaxial cable to the frame.
      Demander à FixBot
    4. iPad Mini 6 Front Camera Replacement, Reposition the coaxial cable: étape 18, image 1 de 2 iPad Mini 6 Front Camera Replacement, Reposition the coaxial cable: étape 18, image 2 de 2
      • Use tweezers, or your fingers, to pull the coaxial cable away from the frame, making sure to separate the tape keeping it in place.
      Demander à FixBot
    5. iPad Mini 6 Front Camera Replacement, Disconnect the volume button board: étape 19, image 1 de 2 iPad Mini 6 Front Camera Replacement, Disconnect the volume button board: étape 19, image 2 de 2
      • Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
      Demander à FixBot
    6. iPad Mini 6 Front Camera Replacement, Disconnect the front camera: étape 20, image 1 de 2 iPad Mini 6 Front Camera Replacement, Disconnect the front camera: étape 20, image 2 de 2
      • Use a spudger to pry up and disconnect the front camera board's press connector secured to the frame.
      Demander à FixBot
    7. iPad Mini 6 Front Camera Replacement, Separate the front camera's adhesive: étape 21, image 1 de 2 iPad Mini 6 Front Camera Replacement, Separate the front camera's adhesive: étape 21, image 2 de 2
      • The front camera is secured to the frame with light adhesive.
      • Insert the flat end of a spudger between the front camera and the frame.
      • Gently pry up while pushing the spudger deeper into the gap to separate the adhesive.
      Demander à FixBot
    8. iPad Mini 6 Front Camera Replacement, Remove the front camera: étape 22, image 1 de 2 iPad Mini 6 Front Camera Replacement, Remove the front camera: étape 22, image 2 de 2
      • Use tweezers, or your fingers to remove the front camera.
      Demander à FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
249 441 Réputation
1 203 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
86 243 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 42
Total : 1,415
