Aller au contenu principal
iPhone 14 Battery Replacement
Ce dont vous avez besoin
  1. iPhone 14 Battery Replacement, Remove the pentalobe screws: étape 1, image 1 de 2 iPhone 14 Battery Replacement, Remove the pentalobe screws: étape 1, image 2 de 2
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Battery Replacement, Mark your opening picks: étape 2, image 1 de 3 iPhone 14 Battery Replacement, Mark your opening picks: étape 2, image 2 de 3 iPhone 14 Battery Replacement, Mark your opening picks: étape 2, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 14 Battery Replacement, Tape over any cracks: étape 3, image 1 de 2 iPhone 14 Battery Replacement, Tape over any cracks: étape 3, image 2 de 2
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
  4. iPhone 14 Battery Replacement, Anti-Clamp instructions: étape 4, image 1 de 3 iPhone 14 Battery Replacement, Anti-Clamp instructions: étape 4, image 2 de 3 iPhone 14 Battery Replacement, Anti-Clamp instructions: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Follow this guide to secure your screen with the included tape.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 14 Battery Replacement: étape 5, image 1 de 3 iPhone 14 Battery Replacement: étape 5, image 2 de 3 iPhone 14 Battery Replacement: étape 5, image 3 de 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 14 Battery Replacement: étape 6, image 1 de 2 iPhone 14 Battery Replacement: étape 6, image 2 de 2
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The glass should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the rear glass when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone 14 Battery Replacement, Heat the bottom edge: étape 7, image 1 de 1
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 14 Battery Replacement, Insert an opening pick: étape 8, image 1 de 3 iPhone 14 Battery Replacement, Insert an opening pick: étape 8, image 2 de 3 iPhone 14 Battery Replacement, Insert an opening pick: étape 8, image 3 de 3
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  9. iPhone 14 Battery Replacement, Heat the left edge: étape 9, image 1 de 1
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  10. iPhone 14 Battery Replacement, Slice the left edge adhesive: étape 10, image 1 de 3 iPhone 14 Battery Replacement, Slice the left edge adhesive: étape 10, image 2 de 3 iPhone 14 Battery Replacement, Slice the left edge adhesive: étape 10, image 3 de 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 14 Battery Replacement, Rear glass information: étape 11, image 1 de 1
    • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
  12. iPhone 14 Battery Replacement, Heat the right edge: étape 12, image 1 de 1
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the rear glass is slightly too hot to touch.
  13. iPhone 14 Battery Replacement, Slice the right edge adhesive: étape 13, image 1 de 3 iPhone 14 Battery Replacement, Slice the right edge adhesive: étape 13, image 2 de 3 iPhone 14 Battery Replacement, Slice the right edge adhesive: étape 13, image 3 de 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
  14. iPhone 14 Battery Replacement, Heat the top edge: étape 14, image 1 de 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  15. iPhone 14 Battery Replacement, Slice the top edge adhesive: étape 15, image 1 de 3 iPhone 14 Battery Replacement, Slice the top edge adhesive: étape 15, image 2 de 3 iPhone 14 Battery Replacement, Slice the top edge adhesive: étape 15, image 3 de 3
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  16. iPhone 14 Battery Replacement: étape 16, image 1 de 3 iPhone 14 Battery Replacement: étape 16, image 2 de 3 iPhone 14 Battery Replacement: étape 16, image 3 de 3
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
  17. iPhone 14 Battery Replacement, Open the iPhone: étape 17, image 1 de 3 iPhone 14 Battery Replacement, Open the iPhone: étape 17, image 2 de 3 iPhone 14 Battery Replacement, Open the iPhone: étape 17, image 3 de 3
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
  18. iPhone 14 Battery Replacement, Unfasten the battery connector cover screws: étape 18, image 1 de 2 iPhone 14 Battery Replacement, Unfasten the battery connector cover screws: étape 18, image 2 de 2
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 14 Battery Replacement, Remove the battery connector cover: étape 19, image 1 de 3 iPhone 14 Battery Replacement, Remove the battery connector cover: étape 19, image 2 de 3 iPhone 14 Battery Replacement, Remove the battery connector cover: étape 19, image 3 de 3
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  20. iPhone 14 Battery Replacement, Disconnect the battery: étape 20, image 1 de 2 iPhone 14 Battery Replacement, Disconnect the battery: étape 20, image 2 de 2
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 14 Battery Replacement, Unfasten the charging coil connector cover screw: étape 21, image 1 de 2 iPhone 14 Battery Replacement, Unfasten the charging coil connector cover screw: étape 21, image 2 de 2
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  22. iPhone 14 Battery Replacement, Remove the charging coil connector bracket: étape 22, image 1 de 2 iPhone 14 Battery Replacement, Remove the charging coil connector bracket: étape 22, image 2 de 2
    • Use a pair of tweezers to remove the charging coil connector cover.
  23. iPhone 14 Battery Replacement, Disconnect the charging coil: étape 23, image 1 de 2 iPhone 14 Battery Replacement, Disconnect the charging coil: étape 23, image 2 de 2
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
  24. iPhone 14 Battery Replacement, Remove the rear glass assembly: étape 24, image 1 de 2 iPhone 14 Battery Replacement, Remove the rear glass assembly: étape 24, image 2 de 2
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
  25. iPhone 14 Battery Replacement, Locate the adhesive pull-tabs: étape 25, image 1 de 1
    • Two stretch adhesive strips secure the battery to the case. They're both accessed from the top edge of the battery.
    • Each adhesive strip has a black pull-tab at the end, which is lightly adhered to the edge of the battery.
    • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
    • If the strips break, don't panic! They don't always work as intended. Keep reading for tips on removing broken strips.
  26. iPhone 14 Battery Replacement, Remove the stretch-release adhesive: étape 26, image 1 de 3 iPhone 14 Battery Replacement, Remove the stretch-release adhesive: étape 26, image 2 de 3 iPhone 14 Battery Replacement, Remove the stretch-release adhesive: étape 26, image 3 de 3
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    • Use a pair of blunt-nosed tweezers to peel up the two battery adhesive pull-tabs along the top edge of the battery.
  27. iPhone 14 Battery Replacement: étape 27, image 1 de 3 iPhone 14 Battery Replacement: étape 27, image 2 de 3 iPhone 14 Battery Replacement: étape 27, image 3 de 3
    • Grab the first pull-tab with your fingers or wrap it around a spudger and slowly pull it away from the battery, toward the top of the iPhone.
    • Pull out hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery but hold the iPhone firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strip, and then proceed as instructed below.
  28. iPhone 14 Battery Replacement: étape 28, image 1 de 3 iPhone 14 Battery Replacement: étape 28, image 2 de 3 iPhone 14 Battery Replacement: étape 28, image 3 de 3
    • Grab the second pull-tab with your fingers or the center of a spudger and pull it away from the battery, toward the top of the iPhone.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
  29. iPhone 14 Battery Replacement, How to remove a stuck battery: étape 29, image 1 de 3 iPhone 14 Battery Replacement, How to remove a stuck battery: étape 29, image 2 de 3 iPhone 14 Battery Replacement, How to remove a stuck battery: étape 29, image 3 de 3
    • If you're still having trouble removing the battery, apply a few drops of high concentration (90% or higher) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use an opening pick or the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  30. iPhone 14 Battery Replacement, Remove the battery: étape 30, image 1 de 2 iPhone 14 Battery Replacement, Remove the battery: étape 30, image 2 de 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off before installing your new battery.
    • If your new battery didn't come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
14 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
123 785 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 131 tutoriels rédigés
4 commentaires
Salut.
Je veux savoir plus de cette formation dépannage.
cfas fix - Réponse
this is iPhone 14, title error, not iPhone 14 Pro
Wells Zhang - Réponse
I think this guide is wrong -- my iPhone 14 has a metal plate inside, covering the battery. The iPhone 14 screen replacement guide appears to be correct, though.
Olivia Farmen - Réponse
Hat ohne Probleme funktioniert. Sehr gute Anleitung. Vielen Dank
Thomas Langthaler - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 158
7 derniers jours : 1,119
30 derniers jours : 4,134
Total : 94,337
