Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 14 Plus Taptic Engine Replacement
Vues: 4,3 k
Afficher les statistiques :
Dernières 24 heures :
7
Sept derniers jours :
33
Trente derniers jours :
164
Total :
4 314
Commentaires: 32
32 commentaires d'étapes.
Terminé: 0
Personne n'a marqué ce tutoriel comme « terminé ». Serez-vous le premier ?
Favoris: 0
Personne n'a mis ce tutoriel en favori (ni ne s'y est abonné). Serez-vous le premier ?
Temps nécessaire: 1 - 2 heures
Difficulté: Modérée
Use this guide to remove and replace the Taptic Engine in an iPhone 14 Plus. The Taptic Engine produces your iPhone's vibration and haptic feedback functions.
This guide was created using the A2886 (international) model. If you're fixing a different iPhone 14 Plus model, there may be some visual discrepancies, but the procedure should be the same.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
Ce dont vous avez besoin
Pièces
Outils
    1. iPhone 14 Plus Taptic Engine Replacement, Remove the pentalobe screws: étape 1, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Remove the pentalobe screws: étape 1, image 2 de 2
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
      Demander à FixBot
      Ajouter un commentaire
    1. iPhone 14 Plus Taptic Engine Replacement, Mark your opening picks: étape 2, image 1 de 3 iPhone 14 Plus Taptic Engine Replacement, Mark your opening picks: étape 2, image 2 de 3 iPhone 14 Plus Taptic Engine Replacement, Mark your opening picks: étape 2, image 3 de 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Demander à FixBot
    1. iPhone 14 Plus Taptic Engine Replacement, Tape over any cracks: étape 3, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Tape over any cracks: étape 3, image 2 de 2
      • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
      • If all else fails, you can superglue the suction cup to the rear glass.
      Demander à FixBot
    2. iPhone 14 Plus Taptic Engine Replacement, Heat the bottom edge: étape 4, image 1 de 1
      • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the rear glass is slightly too hot to touch.
      • Never leave your heat gun in one spot for an extended period of time.
      Demander à FixBot
    3. iPhone 14 Plus Taptic Engine Replacement, Insert an opening pick: étape 5, image 1 de 3 iPhone 14 Plus Taptic Engine Replacement, Insert an opening pick: étape 5, image 2 de 3 iPhone 14 Plus Taptic Engine Replacement, Insert an opening pick: étape 5, image 3 de 3
      • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
      • Insert an opening pick into the gap.
      • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
      Demander à FixBot
    4. iPhone 14 Plus Taptic Engine Replacement, Heat the left edge: étape 6, image 1 de 1
      • Heat the left edge of the iPhone until the rear glass is slightly too hot to touch.
      Demander à FixBot
    5. iPhone 14 Plus Taptic Engine Replacement, Slice the left edge adhesive: étape 7, image 1 de 3 iPhone 14 Plus Taptic Engine Replacement, Slice the left edge adhesive: étape 7, image 2 de 3 iPhone 14 Plus Taptic Engine Replacement, Slice the left edge adhesive: étape 7, image 3 de 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Demander à FixBot
    6. iPhone 14 Plus Taptic Engine Replacement, Heat the right edge: étape 8, image 1 de 1
      • Heat the right edge of the iPhone (the edge with the power button) until the rear glass is slightly too hot to touch.
      Demander à FixBot
    7. iPhone 14 Plus Taptic Engine Replacement, Screen information: étape 9, image 1 de 1
      • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
      Demander à FixBot
    8. iPhone 14 Plus Taptic Engine Replacement, Slice the right edge adhesive: étape 10, image 1 de 3 iPhone 14 Plus Taptic Engine Replacement, Slice the right edge adhesive: étape 10, image 2 de 3 iPhone 14 Plus Taptic Engine Replacement, Slice the right edge adhesive: étape 10, image 3 de 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
      Demander à FixBot
    9. iPhone 14 Plus Taptic Engine Replacement, Heat the top edge: étape 11, image 1 de 1
      • Heat the top edge of the iPhone until the rear glass is slightly too hot to touch.
      Demander à FixBot
    10. iPhone 14 Plus Taptic Engine Replacement, Slice the top edge adhesive: étape 12, image 1 de 3 iPhone 14 Plus Taptic Engine Replacement, Slice the top edge adhesive: étape 12, image 2 de 3 iPhone 14 Plus Taptic Engine Replacement, Slice the top edge adhesive: étape 12, image 3 de 3
      • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
      Demander à FixBot
    11. iPhone 14 Plus Taptic Engine Replacement: étape 13, image 1 de 3 iPhone 14 Plus Taptic Engine Replacement: étape 13, image 2 de 3 iPhone 14 Plus Taptic Engine Replacement: étape 13, image 3 de 3
      • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
      • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
      • Don't try to fully separate the rear glass yet, as there's a fragile ribbon cable connecting it to the iPhone's logic board.
      Demander à FixBot
    12. iPhone 14 Plus Taptic Engine Replacement, Open the iPhone: étape 14, image 1 de 3 iPhone 14 Plus Taptic Engine Replacement, Open the iPhone: étape 14, image 2 de 3 iPhone 14 Plus Taptic Engine Replacement, Open the iPhone: étape 14, image 3 de 3
      • Remove your suction handle from the rear glass.
      • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
      • Be careful not to strain the short charging coil flex cable.
      • Lean the rear glass against something to keep it propped up while you're working on the phone.
      • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
      • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
      Demander à FixBot
    13. iPhone 14 Plus Taptic Engine Replacement, Unfasten the battery connector cover screws: étape 15, image 1 de 1
      Outil utilisé dans cette étape :
      Magnetic Project Mat
      $19.95
      • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Demander à FixBot
    14. iPhone 14 Plus Taptic Engine Replacement, Remove the battery connector cover: étape 16, image 1 de 3 iPhone 14 Plus Taptic Engine Replacement, Remove the battery connector cover: étape 16, image 2 de 3 iPhone 14 Plus Taptic Engine Replacement, Remove the battery connector cover: étape 16, image 3 de 3
      • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
      • Remove the battery connector cover.
      Demander à FixBot
    15. iPhone 14 Plus Taptic Engine Replacement, Disconnect the battery: étape 17, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Disconnect the battery: étape 17, image 2 de 2
      • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Demander à FixBot
    16. iPhone 14 Plus Taptic Engine Replacement, Unfasten the charging coil connector cover: étape 18, image 1 de 1
      • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
      Demander à FixBot
    17. iPhone 14 Plus Taptic Engine Replacement, Remove the charging coil connector bracket: étape 19, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Remove the charging coil connector bracket: étape 19, image 2 de 2
      • Use a pair of tweezers to remove the charging coil connector cover.
      Demander à FixBot
    18. iPhone 14 Plus Taptic Engine Replacement, Disconnect the charging coil: étape 20, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Disconnect the charging coil: étape 20, image 2 de 2
      • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
      Demander à FixBot
    19. iPhone 14 Plus Taptic Engine Replacement, Remove the rear glass assembly: étape 21, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Remove the rear glass assembly: étape 21, image 2 de 2
      • Remove the rear glass assembly.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, pause here if you wish to replace the rear glass adhesives.
      Demander à FixBot
    1. iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine screws: étape 22, image 1 de 1
      • Use a Phillips screwdriver to remove the four screws securing the Taptic Engine.
      • Two 1.7 mm-long screws
      • One 1.4 mm-long screw
      • One 1.8 mm-long screw
      Demander à FixBot
    2. iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine connector bracket: étape 23, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine connector bracket: étape 23, image 2 de 2
      • Use a pair of tweezers to remove the Taptic Engine connector bracket.
      Demander à FixBot
    3. iPhone 14 Plus Taptic Engine Replacement, Disconnect the Taptic Engine: étape 24, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Disconnect the Taptic Engine: étape 24, image 2 de 2
      • Use the pointed end of a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
      Demander à FixBot
    4. iPhone 14 Plus Taptic Engine Replacement, Remove the standoff screw: étape 25, image 1 de 1
      Standoff Screwdriver for iPhones
      $5.49
      • Use a standoff driver to remove the 3.1 mm-long standoff screw.
      • Standoff screws are best removed using a dedicated standoff driver or driver bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Demander à FixBot
    5. iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine: étape 26, image 1 de 2 iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine: étape 26, image 2 de 2
      • Use a pair of tweezers or your fingers to remove the Taptic Engine.
      Demander à FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Dominik Schnabelrauch
Membre depuis le 11/23/16
266 477 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
72 895 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 33
30 derniers jours : 164
Total : 4,314
