Introduction
Tutoriel pré-requis pour remplacer le connecteur de charge Lightning et le haut-parleur
Ce dont vous avez besoin
Retirez les vis qui sécurisent le connecteur de Lightning et l'enceinte du haut-parleur au boîtier suivantes :
une vis cruciforme 2,5 mm
deux vis cruciformes 3,3 mm
une vis cruciforme 2,9 mm
deux vis cruciformes 1,5 mm
une vis cruciforme 2,8 mm
Utilisez le bout plat d'un spudger pour soulever délicatement les câbles du connecteur Lightning et de l'enceinte du haut-parleur du boîtier.
this is NOT the right way to remove the speaker, anyone following this guide will do unnecessary damage to the phone.
Speaker is one of the "official" serviceable part of iPhone 5. Which means you don't have to remove the logic board and the battery. Skip straight to step 27, peel up the home button contact flex, remove the red, blue, yellow and the green screw, peel loose the grounding flex stuck around the headphone jack, then remove the flex and the speaker as one part. NEVER remove the lightning connector flex unless you really need to.
I agree, there is no need to remove the battery or the main board, simply remove the two screws on the right hand side of the buzzer (the larger one on the right and smaller one by dock) and remove the screw next to the home button contact, the buzzer simply slides out, 5 minute job.
Heyi successfully took out this speaker and jack but i found 4 small rings and i dont know where they were placed
Retirez du boîtier le connecteur Lightning et l'enceinte du haut-parleur.
Make sure to clean any bits of golden glue left on the phone case
The metal washers appear to have come from the bottom side of the lightning connector. Underneath the four screws. Two of mine were stuck on the old part that I had removed. I noticed this after installing the parts.
Any idea what is the strip which is stuck on the speaker, which helps connect the two screws? does it have any specific functionality or is it just to keep the speaker in place?
I see that it just connects two end points to the iphone body.
That part is the cellular antenna. iPhone 5 Cellular Antenna
slessard -
I am trying to find these washers that go under the lightning connector as to where I can find an extra one of these for a repair and also need some help figuring out after replacing power cable, LCD and screen, lightning connector and both flex cables on the motherboard, the back case and the battery why the iPhone 5 is not charging or powering on... If you can help me figure out this issue I would greatly appreciate it.
Could one missing washer cause this to be the issue.
Pour remonter votre appareil, suivez les étapes dans l'ordre inverse.
Merci à ces traducteurs :
100%
Dina Rafanomezantsoa nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Every step after this one is vague and hard to understand. Seems to be a lot missing. Proceed with extreme caution!
Joe Wasser - Réponse
