Aller au contenu principal
iPhone 6 Wi-Fi Antenna Replacement
Ce dont vous avez besoin
  1. iPhone 6 Wi-Fi Antenna Replacement, Pentalobe Screws: étape 1, image 1 de 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Wi-Fi Antenna Replacement, Anti-Clamp instructions: étape 2, image 1 de 3 iPhone 6 Wi-Fi Antenna Replacement, Anti-Clamp instructions: étape 2, image 2 de 3 iPhone 6 Wi-Fi Antenna Replacement, Anti-Clamp instructions: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Wi-Fi Antenna Replacement: étape 3, image 1 de 3 iPhone 6 Wi-Fi Antenna Replacement: étape 3, image 2 de 3 iPhone 6 Wi-Fi Antenna Replacement: étape 3, image 3 de 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Wi-Fi Antenna Replacement, Manual Opening Procedure: étape 4, image 1 de 1
    Anti-Clamp
    $24.95
    J'achète
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Wi-Fi Antenna Replacement: étape 5, image 1 de 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Wi-Fi Antenna Replacement: étape 6, image 1 de 2 iPhone 6 Wi-Fi Antenna Replacement: étape 6, image 2 de 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Wi-Fi Antenna Replacement, Opening up the phone: étape 7, image 1 de 3 iPhone 6 Wi-Fi Antenna Replacement, Opening up the phone: étape 7, image 2 de 3 iPhone 6 Wi-Fi Antenna Replacement, Opening up the phone: étape 7, image 3 de 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. iPhone 6 Wi-Fi Antenna Replacement: étape 8, image 1 de 3 iPhone 6 Wi-Fi Antenna Replacement: étape 8, image 2 de 3 iPhone 6 Wi-Fi Antenna Replacement: étape 8, image 3 de 3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 6 Wi-Fi Antenna Replacement, Removing the battery connector bracket screws: étape 9, image 1 de 1
    Magnetic Project Mat
    $19.95
    J'achète
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  10. iPhone 6 Wi-Fi Antenna Replacement: étape 10, image 1 de 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Wi-Fi Antenna Replacement, Disconnecting the battery connector: étape 11, image 1 de 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Wi-Fi Antenna Replacement, Removing the front panel assembly cable bracket screws: étape 12, image 1 de 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  13. iPhone 6 Wi-Fi Antenna Replacement: étape 13, image 1 de 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Wi-Fi Antenna Replacement: étape 14, image 1 de 2 iPhone 6 Wi-Fi Antenna Replacement: étape 14, image 2 de 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6 Wi-Fi Antenna Replacement: étape 15, image 1 de 2 iPhone 6 Wi-Fi Antenna Replacement: étape 15, image 2 de 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  16. iPhone 6 Wi-Fi Antenna Replacement: étape 16, image 1 de 2 iPhone 6 Wi-Fi Antenna Replacement: étape 16, image 2 de 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Wi-Fi Antenna Replacement: étape 17, image 1 de 2 iPhone 6 Wi-Fi Antenna Replacement: étape 17, image 2 de 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Wi-Fi Antenna Replacement, Separating front panel assembly and rear case: étape 18, image 1 de 1
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Wi-Fi Antenna Replacement, Wi-Fi Antenna: étape 19, image 1 de 1
    • Remove the following Phillips screws from the upper cable bracket:
    • One 2.9 mm screw
    • One 2.2 mm screw
  20. iPhone 6 Wi-Fi Antenna Replacement: étape 20, image 1 de 2 iPhone 6 Wi-Fi Antenna Replacement: étape 20, image 2 de 2
    • Remove the upper cable bracket from the iPhone.
  21. iPhone 6 Wi-Fi Antenna Replacement: étape 21, image 1 de 1
    • Remove the following four Phillips screws from the Wi-Fi antenna:
    • One 1.5 mm screw
    • One 1.4 mm screw
    • Two 2.1 mm screws
  22. iPhone 6 Wi-Fi Antenna Replacement: étape 22, image 1 de 2 iPhone 6 Wi-Fi Antenna Replacement: étape 22, image 2 de 2
    J'achète
    • Remove the Wi-Fi antenna from the iPhone.
    • Be careful not to touch any metal to metal contact points with your bare fingers—use tweezers or gloves. Finger oils may disrupt conductivity. If you do touch any of these components, clean them with a degreaser like windex or isopropyl alcohol before reassembly.
210 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
466 301 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
137 membres
17 457 tutoriels rédigés
21 commentaires
If your iphone 6 has bad wifi signal, replacing this unit alone won't fix the problem. I had to replace the cable (PN: T308S) connecting this unit to the logic board. I bought it on eBay. It came with completely differnt part number, but worked perfectly
khanhag005 - Réponse
Yeah khanhag005 is right, replacing this piece alone most likely won't do anything to help your WiFi / Bluetooth.
Replace the WiFi / Bluetooth cable if your WiFi or Bluetooth isn't working or if your WiFi button in greyed out. I bought mine on eBay for less than $3 and it took me less than an hour to do using the guide Remplacement de la nappe d'antenne de l'iPhone 6
ForumHermit -
Referring to the Antenna Flex Cable Replacement post comment on Aug30/31 post by Andy, 85 was referencing the grey out probably can't be fixed by replacing the cable neither
wonder if anyone has the actually grey out wifi issue and know which part to order?
Walter A -
I had an issue with my iPhone with poor WiFi reception and most of the time couldn't connect to WiFi at all. If the WiFi signal from a router was strong, that was the only time I could connect. The Apple store ran their diagnostics and told me there was no fault detected and the option was to pay $429 AUD for a replacement phone so I did some fault finding myself. After reinstalling the firmware through a DFU restore and reinstalling the software to rule out both those contenders it was pretty certain it was a hardware issue.
I replaced the WiFi antenna and also the antenna flex cable while I was in there. The issue is resolved and phone is functioning perfectly. I cannot say which part solved the issue but figured it was worth changing both out at the same time. The repair guide was spot on and super easy to follow, parts supplied from iFIXIT were good quality and did the job. Overall coast was just over $50 AUD including tools and shipping. Thank you!
tooeasy - Réponse
Bought the new antenna and the required tools from amazing and followed this guide to the last detail. I was successfully able to replace my antenna and solve my wifi and gps issues. Thanks a lot.
Prakhar Singh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 63
30 derniers jours : 302
Total : 221,684
