Aller au contenu principal
iPhone 7 - U3101 Audio IC Replacement
Vidéo d'introduction
  1. iPhone 7 - U3101 Audio IC Replacement, Remove U3101: étape 1, image 1 de 1
    • Remove the chip cleanly, with hot air. On my Quick 861DE rework station, I use the settings 400 °C and 100L/min. For you to decide which settings you prefer, you can find the Quick 861DW on the shop.
    • Clean the tracks with a soldering iron, tin and flux. I use a tip about 1mm in diameter with my JBC Nase 2C, at 360 ° C.
    • Clean the map.
    • Inspect the card under the microscope. We can see on the picture that a track is missing!
    • If we compare to the diagram on the PhoneBoard software;
    • We observe very clearly that we will be able to put a wire to redo this connection, focusing on R1103.
    • Take copper wire with a diameter of 0.02mm
    • Apply flux and tin the wire with an iron.
    • Scratch the trail from C12 to R1103.
    • Laminate this track with tin.
    • Solder one end of the wire to the resistor. I used a 0.01mm diameter tip.
    • Solder the wire along the previously tinned track.
    • Bring the wire into the C12 slot and try to wrap it to be sure that the chip ball will stick to it.
    • The procedure is the same for F12, H12, J12. A12 and B12 are grounded and are not used for U3101 operation, so there is no need to jump them.
    • E12 is in contact with C1, so if C1 is present there is no need to redo this jumper. D12, G12, J11 and A5 are connected to each other, so even if only one is still connected the phone can still function properly. K12, L12, M12 are "No Connection" so there is no need to replace them.
  2. iPhone 7 - U3101 Audio IC Replacement, Reballing the U3101: étape 5, image 1 de 2 iPhone 7 - U3101 Audio IC Replacement, Reballing the U3101: étape 5, image 2 de 2
    • Put on some flux.
    • Take a soldering iron with tin at the end.
    • Pass over the chip to smooth the balls.
    • Clean.
    • Place a reballing stencil over the chip.
    • Spread some soldering paste.
    • Heat with hot air to form the balls.
    • Extract the chip by pushing with a thin tweezers.
    • Check the size of the balls.
    • And finally we put the chip back.Flow, position and solder with hot air.
    • We let the phone cool, test again and the problem is solved!
To reassemble your device, follow the instructions in reverse order.
22 autres ont terminé cette réparation.
Merci à ces traducteurs :
fr en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Alexandre Isaac
Membre depuis le 04/07/13
2 863 Réputation
8 tutoriels rédigés
Équipe
The Repair Academy Membre de l'équipe The Repair Academy
Business
1 membre
20 tutoriels rédigés
6 commentaires
Are there any micro soldering techs that do business through the mail. I don’t have any close to my area at all that give me wholesale prices any longer, and I am in need BAD!!!! PLEASE RESPOND ASAP! I do mostly iPhones only. Sometimes there are a few oddballs and I live in MA. I need this person to start ASAP. Thanks!
Rachel Kelley - Réponse
Not sure if you still need help, if you ever need anything for iphone, ipad, or Mac book board repair, try itechcarerepair@gmail.com
iTechCare Zhao -
Bonjour merci pour le tuto ma question et de savoir quel type d’éteint faut utiliser. Merci
reda bereksi reguig - Réponse
Holy moly, you guys are on a whole other level !!!!
Alex Campbell - Réponse
Would replacing the logic board work just as well ?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 18
7 derniers jours : 79
30 derniers jours : 395
Total : 59,463
