Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPod 3rd Generation Hard Drive Replacement
Ce dont vous avez besoin
  1. iPod 3rd Generation Hard Drive Replacement, Case: étape 1, image 1 de 1
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
    Demander à FixBot
    Ajouter un commentaire
  2. iPod 3rd Generation Hard Drive Replacement: étape 2, image 1 de 3 iPod 3rd Generation Hard Drive Replacement: étape 2, image 2 de 3 iPod 3rd Generation Hard Drive Replacement: étape 2, image 3 de 3
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should open easily.
    Demander à FixBot
  3. iPod 3rd Generation Hard Drive Replacement: étape 3, image 1 de 1
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector at the top, and lay the rear panel next to the front half of the iPod.
    Demander à FixBot
  4. iPod 3rd Generation Hard Drive Replacement: étape 4, image 1 de 2 iPod 3rd Generation Hard Drive Replacement: étape 4, image 2 de 2
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • The headphone jack connector is unusually tall. When prying, be careful to not separate the lower, plastic part of the connector from the ribbon cable. Pry between the connector and the socket, not between the two halves of the connector.
    Demander à FixBot
  5. iPod 3rd Generation Hard Drive Replacement, Hard Drive: étape 5, image 1 de 1
    • Lift up the hard drive with one hand and carefully disconnect the hard drive ribbon from the logic board.
    • Lift the hard drive out of the iPod.
    Demander à FixBot
  6. iPod 3rd Generation Hard Drive Replacement: étape 6, image 1 de 1
    • Peel back the metallic tape connecting the hard drive ribbon to the blue mounting bracket.
    Demander à FixBot
  7. iPod 3rd Generation Hard Drive Replacement: étape 7, image 1 de 1
    • Use a spudger to carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    Demander à FixBot
  8. iPod 3rd Generation Hard Drive Replacement: étape 8, image 1 de 1
    • Lift the hard drive mounting bracket and cable off the hard drive.
    Demander à FixBot
  9. iPod 3rd Generation Hard Drive Replacement: étape 9, image 1 de 1
    • Lift the blue and white mounting bracket off the other side of the hard drive.
    Demander à FixBot
  10. iPod 3rd Generation Hard Drive Replacement: étape 10, image 1 de 1
    • Hard drive remains.
    Demander à FixBot
36 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
1 commentaire de tutoriel
Works with iPod 3rd Generation 10GB also.
Xavier Delapree - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 38
30 derniers jours : 186
Total : 51,644
