Aller au contenu principal
iRobot Roomba 890 Charging Contacts Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: étape 1, image 1 de 2 iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: étape 1, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: étape 2, image 1 de 1
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: étape 3, image 1 de 1
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: étape 4, image 1 de 2 iRobot Roomba 890 Charging Contacts Replacement: étape 4, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: étape 5, image 1 de 2 iRobot Roomba 890 Charging Contacts Replacement: étape 5, image 2 de 2
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: étape 6, image 1 de 2 iRobot Roomba 890 Charging Contacts Replacement: étape 6, image 2 de 2
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: étape 7, image 1 de 3 iRobot Roomba 890 Charging Contacts Replacement: étape 7, image 2 de 3 iRobot Roomba 890 Charging Contacts Replacement: étape 7, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: étape 8, image 1 de 2 iRobot Roomba 890 Charging Contacts Replacement: étape 8, image 2 de 2
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: étape 9, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: étape 10, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: étape 11, image 1 de 1
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 autres ont terminé cette réparation.
Devin Steiblin
Membre depuis le 03/28/22
442 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Petersen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-3, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G3
3 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 115
Total : 6,447
