Aller au contenu principal
Remplacement de la prise d'alimentation du Apple Thunderbolt Display
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Apple Thunderbolt Display EMI Filter Replacement: étape 0, image 1 de 3 Apple Thunderbolt Display EMI Filter Replacement: étape 0, image 2 de 3 Apple Thunderbolt Display EMI Filter Replacement: étape 0, image 3 de 3
  • The EMI filter is connected by three screws. Use the T10 screwdriver to remove them.
  • The screw that holds in both the filter and a wire that is connected to it is a different size and should be kept identifiable from the other two screws.
  • The green and yellow wire that was held in by the different screw is tucked behind another component. To get it out, squeeze it behind the black wire and the filter will be able to be removed from the casing.
L'adaptateur d'alimentation est connecté par trois vis. Utilisez le tournevis T10 pour les supprimer.
La vis qui maintient l'adaptateur secteur et le fil qui y est connecté sont de taille différente et doivent rester identifiables des deux autres vis.
Le fil vert et jaune retenu par la vis différente est dissimulé derrière un autre composant. Pour le sortir, pincez-le derrière le fil noir pour pouvoir débrancher l'adaptateur secteur du boîtier.
-[* red] The power adapter is connected by three screws. Use the T10 screwdriver to remove them.
-[* icon_note] The screw that holds in both the AC adapter and a wire that is connected to it is a different size and should be kept identifiable from the other two screws.
-[* black] The green and yellow wire that was held in by the different screw is tucked behind another component. To get it out, squeeze it behind the black wire and the power adapter will be able to be removed from the casing.
+[* red] The EMI filter is connected by three screws. Use the T10 screwdriver to remove them.
+[* orange] The screw that holds in both the filter and a wire that is connected to it is a different size and should be kept identifiable from the other two screws.
+[* black] The green and yellow wire that was held in by the different screw is tucked behind another component. To get it out, squeeze it behind the black wire and the filter will be able to be removed from the casing.
