Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Traduction de l’étape 5
Étape 5
Pry up the proximity sensor
Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
Gently wiggle and lift to separate the module from its notch in the front panel.
[title] Pry up the proximity sensor |
[* black] Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module. |
[* black] Gently wiggle and lift to separate the module from its notch in the front panel. |
[* icon_note] It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work. |
