Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Traduction de l’étape 4
Étape 4
Pry up the microphone
Carefully slide the flat edge of a spudger underneath the flex cable below the microphone.
Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel. If the microphone remains difficult to separate, apply more heat.
[title] Pry up the microphone |
[* black] Carefully slide the flat edge of a spudger underneath the flex cable below the microphone. |
[* black] Twist gently to separate the microphone, while being careful not to strain or damage the flex cable. |
[* black] If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel. If the microphone remains difficult to separate, apply more heat. |
