Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 20 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPod for about a minute in order to soften up the adhesive underneath. The bottom of the screen (near the home button) is held in place with strong adhesive.
  • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPod for about a minute in order to soften up the adhesive underneath.
  • The bottom of the screen (near the home button) is held in place with strong adhesive.
  • As you start prying the screen off in the next stages, you may need to apply more heat to keep the glue warm and flexible.
Le bas de l'écran (près du bouton home) est maintenu en place par un adhésif solide.
Utilisez un pistolet à air chaud ou un sèche-cheveux (faible réglage) pour ramollir l'adhésif.
Quand vous commencez à ouvrir l'écran au cous des prochaines étapes, vous devrez peut-être appliquer plus de chaleur pour que la colle reste chaude et souple.
[title] Soften* black] Use a hairdryer or [guide|25705|prepare an iOpener|new_window=true] and apply it to the lower edge of the iPod for about a minute in order to soften up the adhesive with hair dryer
[* black
underneath.
[* red
] The bottom of the screen (near the home button) is held in place with strong adhesive.
[* black] Use a heat gun or hair dryer (low setting) to soften the
adhesive.
[* black
underneath.
[* red
adhesive.
[* black] As you start prying the screen off in the next stages, you may need to apply more heat to keep the glue warm and flexible.
