Aller au contenu principal
Remplacement de la batterie du MacBook Pro 15" Touch Bar 2019
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
    Follow these instructions to safely remove the glued-in battery from your MacBook Pro using an iFixit kit with adhesive remover. The liquid solvent in the kit dissolves the adhesive securing the battery, allowing you to remove it more easily.
    '''***iFixit adhesive remover is flammable—'''***use it in a well-ventilated area, and do not smoke or work near an open flame.
    '''***To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure.'''*** A charged lithium-ion battery can be very dangerous if accidentally punctured. [[What to do with a swollen battery|If your battery looks puffy or swollen, take extra precautions.]]
    '''***Note'''***: The solvent used to dissolve the battery adhesive can damage certain plastics. Follow all instructions and take care where you apply the adhesive remover.
      Étapes du tutoriel
