Aller au contenu principal
Remplacement de l'écran du Google Pixel 3 XL
Anglais
Français
Traduction de l’étape 7
Étape 7
Google Pixel 3 XL Screen Replacement: étape 0, image 1 de 3 Google Pixel 3 XL Screen Replacement: étape 0, image 2 de 3 Google Pixel 3 XL Screen Replacement: étape 0, image 3 de 3
  • The screen is still adhered to the frame by a large adhesive pad near the center of the screen.
  • Insert a spudger or plastic opening card into the edge and press in to slice through the deeper adhesive.
  • Continue slicing until the screen is freed from the frame.
Le milieu de l'écran colle toujours au châssis par un gros morceau d'adhésif.
Insérez une spatule ou une carte en plastique sur le côté et enfoncez-la pour faire céder cet adhésif.
Continuez jusqu'à ce que l'écran soit détaché du châssis.
-[* icon_note] The screen is still adhered to the frame by a large adhesive pad near the center. of the screen.
-[* black] Insert a spudger or plastic opening card into the edge and press in to slice through the deeper adhesive.
+[* icon_note] The screen is still adhered to the frame by a large adhesive pad near the center of the screen.
+[* black] Insert a spudger or [product|IF145-101|plastic opening card] into the edge and press in to slice through the deeper adhesive.
[* black] Continue slicing until the screen is freed from the frame.
