Aller au contenu principal
Remplacement de l'écran du Google Pixel 3 XL
Anglais
Français
Conditions préalables au tutoriel
Tous les tutoriels prérequis doivent être traduits avant que cette traduction soit considérée comme complète.
Procédure d'ouverture du Google Pixel 3 XL
Déconnexion de la batterie du Google Pixel 3 XL
Informations sur le tutoriel
= Terminé = Incomplet
    Follow this guide to remove and replace a broken screen for your Google Pixel 3 XL. '''This procedure is for replacement screens that are not pre-mounted onto a frame.''' Due to the Pixel’s design, you will have to remove the back panel in order to disconnect the screen connector.
    ***This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides [[Info:content-quality|here|new_window=true]].***
    '''Follow this guide to remove and replace a broken screen for your Google Pixel 3 XL. ***This procedure is for replacement screens that are not pre-mounted onto a frame.*** Due to the Pixel’s design, you will have to remove the back panel in order to disconnect the screen connector.
    Before you begin this procedure, be sure to have a set of replacement adhesives for both the back panel and the screen.
    This procedure will destructively remove the Pixel 3 XL’s screen.'''*** OLEDs cease to work when exposed to oxygen or moisture, and are thus sealed in an airtight encapsulation (this is also why OLED panels turn black underneath a screen crack). ThereIt is no wayvery difficult to replace the front glass alone— the Pixel’s OLED layers are laminated to the glass.
      ***If your Pixel won't turn on after replacing the screen, there is a chance that the phone has silently turned on when the battery is re-connected. Hold the power button for a few seconds until the phone vibrates off. Afterwards, re-connect the screen, and try again.***
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Device/Google%20Pixel%203%20XL|Pixel 3 XL Answers community] for help.[br]
      Étapes du tutoriel
      Étape 1 — Débrancher la nappe de l'écran
      Servez-vous de la pointe d'une spatule (spudger) pour débrancher la nappe de l'écran de sa prise sur la carte mère, le long du bord droit du téléphone.
      Étape 2 — Chauffer le bord long de l'écran
      Retournez le téléphone, l'écran vers le haut.
      Étape 3 — Ouvrir un espace
      Posez une ventouse sur le bord chauffé de l'écran, aussi près que possible du bord.
      Étape 4 — Trancher l'adhésif sur le côté
      Faites glisser le médiator le long du bord de l'écran pour trancher l'adhésif.
      Étape 5 — Chauffer le bord inférieur de l'écran
      Posez un iOpener chauffé sur le bord inférieur de l'écran pendant une minute.
      Étape 6
      Continuez à chauffer et couper jusqu'à ce que vous ayez fait céder l'adhésif sur tout le pourtour du téléphone.
      Étape 7
      Le milieu de l'écran colle toujours au châssis par un gros morceau d'adhésif.
      Étape 8
      Retournez le téléphone, la carte mère vers le haut.
      Étape 9
