Aller au contenu principal
Remplacement de l'écran du Google Pixel 3 XL
Anglais
Français
Traduction de l’étape 9
Étape 9
Google Pixel 3 XL Screen Replacement: étape 0, image 1 de 2 Google Pixel 3 XL Screen Replacement: étape 0, image 2 de 2
  • Flip the phone so that the screen is facing up.
  • Lift the screen from the phone, cutting through any remaining adhesive.
  • Remove the screen.
  • You will have to carefully thread the replacement screen's display cable through the motherboard cutout. If you are having trouble, you can always loosen and partially remove the motherboard.
  • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the speaker grille) or remove adhesive backings from the new part before installing.
  • Follow this guide for instructions on how to apply adhesive to the replacement screen.
  • Be sure to test your repairs before you affix the screen with adhesives.
  • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
Retournez le téléphone, l'écran vers le haut.
Soulevez l'écran du téléphone en coupant tout adhésif restant.
Ôtez l'écran.
Vous allez devoir enfiler soigneusement la nappe de l'écran de remplacement à travers l'encoche de la carte mère. Si vous avez du mal, vous pouvez détacher et retirer partiellement la carte mère.
Consultez ce tutoriel pour savoir comment poser de l'adhésif sur l'écran de remplacement.
[* black] Flip the phone so that the screen is facing up.
[* black] Lift the screen from the phone, cutting through any remaining adhesive.
[* black] Remove the screen.
[* icon_reminder] You will have to carefully thread the replacement screen's display cable through the motherboard cutout. If you are having trouble, you can always [guide|128327|loosen and partially remove the motherboard].
+[* icon_reminder] Compare your new replacement part to the original part. You may need to transfer remaining components (such as the speaker grille) or remove adhesive backings from the new part before installing.
[* icon_reminder] [guide|126585|Follow this guide] for instructions on how to apply adhesive to the replacement screen.
+ [* black] Be sure to test your repairs before you affix the screen with adhesives.
+[* icon_reminder] During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
