Aller au contenu principal
Remplacement de l'écran du Google Pixel 3 XL
Anglais
Français
Traduction de l’étape 8
Étape 8
Google Pixel 3 XL Screen Replacement: étape 0, image 1 de 1
  • Flip the phone over so that the motherboard is facing up.
  • Push the display cable through its motherboard cutout. If you angle the cable such that one end slides under first, you can get it out easier.
  • You can loosen and partially remove the motherboard to create a larger gap.
  • If you are not planning to save the original display, you can just cut the cable to make retrieval easier.
Retournez le téléphone, la carte mère vers le haut.
Faites passer la nappe de l'écran à travers l'encoche de la carte mère. Si vous introduisez d'abord un côté, ce sera plus facile.
Si vous avez du mal, vous pouvez couper la nappe pour faciliter son retrait.
Si vous avez accidentellement tranché la nappe en retirant l'écran, retirez le morceau qui reste.
[* black] Flip the phone over so that the motherboard is facing up.
[* black] Push the display cable through its motherboard cutout. If you angle the cable such that one end slides under first, you can get it out easier.
- [* black] If you are having trouble, you can just cut the cable to make retrieval easier.
-[* icon_note] If you have inadvertently sliced through the display cable while removing the screen, you can just remove the cable stub.
+ [* icon_note] You can [guide|128327|loosen and partially remove the motherboard] to create a larger gap.
+ [* icon_note] If you are not planning to save the original display, you can just cut the cable to make retrieval easier.
