Aller au contenu principal
Remplacement de la batterie du MacBook Pro 13" Touch Bar 2019
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
    Follow these instructions to replace the glued-in battery in your MacBook Pro using an iFixit kit with adhesive remover. The adhesive remover helps weaken the glue securing the old battery, making it easier to remove.
    '''***iFixit adhesive remover is flammable.'''*** Follow this procedure in a well-ventilated area, and don’t smoke or work near an open flame.
    '''***To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure.'''*** If a charged lithium-ion battery is accidentally punctured, a dangerous and uncontrollable fire may result. [[What to do with a swollen battery|If your battery looks puffy or swollen, take extra precautions|new_window=true]].
    '''***Note'''***: The solvent used to dissolve the battery adhesive can damage certain plastics. Follow all instructions and take care where you apply the adhesive remover.
      Étapes du tutoriel
