Aller au contenu principal
Remplacement de la batterie de l'iPhone 12 Pro
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
    iPhone batteries are rated to hold 80% of their capacity for up to 500 charge cycles, which lasts roughly 18-24 months for most users. After that, your iPhone may need to be charged far more frequently, and iOS may warn you that performance is affected (in other words, your phone will run slower). Use this guide to replace your battery and restore your iPhone to like-new performance.
    If your battery is swollen, [[What to do with a swollen battery|take appropriate precautions|new_window=true]].
    '''***Note'''***: After the repairOn iOS 17.6 and earlier, your iPhone may display a warning about the “genuineness” of the battery after the repair, even when using original Apple parts. If your iPhone functions normally, you can safely ignore the warning. On iOS 18 and newer, authenticate your new battery using Apple's [link|https://support.apple.com/en-us/120579|Repair Assistant|new_window=true].
    For optimal performance, after completing this guide, [[Battery Calibration|calibrate]] your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
      ***To reassemble your device, follow the above steps in reverse order.***
      After your repair, depending on the replacement part, you may be able to [link|https://support.apple.com/en-us/120579|calibrate it using Apple's Repair Assistant|new_window=true], available as of iOS 18. Update your device, navigate to Settings ***→*** General ***→***About ***→*** Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Device/iPhone%2012%20Pro|iPhone 12 Pro Answers community] for help.
      Étapes du tutoriel
      Étape 1 — Repérer les bandes adhésives d'extraction
      La batterie est fixée à la coque arrière par quatre bandes adhésive étirables : deux en bas et deux en haut.
      Étape 2 — Décoller les bandes adhésives étirables
      Décollez la première languette d'extraction du bord inférieur de la batterie.
      Étape 3
      Décollez la deuxième languette d'extraction du bord inférieur de la batterie.
      Étape 4
      Saisissez la première languette et éloignez-la lentement de la batterie, en la tirant vers le bas de l'iPhone.
      Étape 5
      Saisissez la deuxième languette et éloignez-la de la batterie, en la tirant vers le bas de l'iPhone.
      Étape 6
      Décollez les deux dernières languettes d'extraction du bord supérieur de la batterie.
      Étape 7
      Suivez la même procédure que tout à l'heure. Tirez sur les deux languettes restantes, une à la fois, pour étirer et décoller l'adhésif qui fixe la batterie. Veillez à ce que les bandes ne restent accrochées nulle part.
      Étape 8 — Comment enlever une batterie récalcitrante
      Si vous avez encore du mal à retirer la batterie, appliquez quelques gouttes d'alcool isopropylique à haute concentration (plus de 90 %) sous le coin de la batterie, là où la ou les bandes adhésives se sont déchirées.
      Étape 9 — Ôter la batterie
      Enlevez la batterie.
