Aller au contenu principal
Remplacement de l'écran de l'iPhone 13 mini
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
    If your iPhone 13 mini screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
    ***The iPhone 13 disables the Face ID function when you replace the screen.*** Due to a microchip that is soldered to the display and transmits the serial number of the individual iPhone, the Face ID function gets lost.
    ***Note***: True Tone functionality is disabled after a screen replacement, even when using an original Apple screen. Additionally, your iPhone may temporarily show a warning about the “genuineness” of the display.
    ***Note***: On iOS 17.6 and earlier, True Tone and auto brightness functionality is disabled after a screen replacement, even when using an original Apple screen. Face ID is also disabled, unless the iPhone is running iOS 15.2 or newer. On iOS 18 and newer, you can calibrate your new screen using Apple's [link|https://support.apple.com/en-us/120579|Repair Assistant|new_window=true] to restore True Tone functionality on genuine screens purchased from Apple.
    You’ll need replacement adhesive to reattach components when reassembling the device.
      ***To reassemble your device, follow the above steps in reverse order.*** Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      After your repair, depending on the replacement part, you may be able to [link|https://support.apple.com/en-us/120579|calibrate it using Apple's Repair Assistant|new_window=true], available as of iOS 18. Update your device, navigate to Settings ***→*** General ***→***About ***→*** Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Check out our [link|https://www.ifixit.com/Answers/Ask/iPhone+13+mini|iPhone 13 mini Answers community] for troubleshooting help.
      Étapes du tutoriel
