Aller au contenu principal
Samsung Galaxy S21 Wireless Charging Coil Replacement
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the battery: étape 0, image 1 de 2 Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the battery: étape 0, image 2 de 2
  • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
  • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
  • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
Insérez ici votre traduction
