Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Traduction de l’étape 9
Étape 9
Work your way around the perimeter of the iMac, adding three more adhesive strips in the same manner.
Working counter-clockwise from strip 13, place:
strip 12 on the top right
strip 11 on the top left
strip 16 on the left vertical
On the iMac Intel 27" Retina 5K Display, strip 12's blue tabs will not line up with the top antenna in the same way as the regular model. This is perfectly acceptable and won't impact the performance of the strips or antenna.
[* black] Work your way around the perimeter of the iMac, adding three more adhesive strips in the same manner. | |
- | [* black] Working counter-clockwise from strip 13, place strip 12 on the top right, strip 11 on the top left, and strip 16 on the left vertical. |
+ | [* black] Working counter-clockwise from strip 13, place: |
+ | [* red] strip 12 on the top right |
+ | [* orange] strip 11 on the top left |
+ | [* yellow] strip 16 on the left vertical |
[* icon_note] These three strips have a hole at each end—always use the smaller hole for alignment for more precise placement. | |
+ | [* green] On the iMac Intel 27" Retina 5K Display, strip 12's blue tabs will not line up with the top antenna in the same way as the regular model. This is perfectly acceptable and won't impact the performance of the strips or antenna. |
