Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Traduction de l’étape 5
Étape 5
Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
+ | [* icon_caution] The rubber gasket surrounding the home button is very thin and tears easily. |
+ | [* black] Apply mild heat (with an [product|IF145-198-2|iOpener], heat gun, or hair dryer) to soften the adhesive securing the home button gasket. |
+ | [* black] Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel. |
