Traduction de l’étape 1
Étape 1
Looking at the LCD casing, you should find two smaller solder joints. There will be one on either side of the camera whoch secure the casing to the circuit board. These are usually shiny and metallic points where the casing connects to the board.
Apply the tip of the heated smolder to the first joint to remove it. Contiune with the other side.
- | [* blue] |
- | [* black] |
+ | [* blue] Looking at the LCD casing, you should find two smaller solder joints. There will be one on either side of the camera whoch secure the casing to the circuit board. These are usually shiny and metallic points where the casing connects to the board. |
+ | [* black] Apply the tip of the heated smolder to the first joint to remove it. Contiune with the other side. |
