Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Traduction de l’étape 4
Étape 4
Repeat for the second strip.
If you removed both strips successfully, skip the next step.
Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
[* black] Repeat for the second strip. |
[* black] If you removed both strips successfully, skip the next [* [* black] Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery. [* icon_caution] Don't try to [* icon_caution] '''Do not''' pry against the logic board or you may damage the phone. [* icon_caution] '''Avoid''' prying at the top left near the volume controls, or you may damage the [https://d3nevzfk7ii3be.cloudfront.net/igi/uWEVFdCRurTInQuC|volume button ribbon cable|new_window=true]. [* icon_note] You can also try the alternative methods in '''the next |
