Traduction de l’étape 6
Étape 6
On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure.
When you lift this off, you will need to disconnect the cables from the other side using the same method as in Step 5.
[* red] On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure. | |
- | [* black] When you lift this off, you will need to disconnect the cables from the other side using the same method as in |
+ | [* black] When you lift this off, you will need to disconnect the cables from the other side using the same method as in Step 5. |
+ | [* icon_reminder] Again, be sure to record which port each cable was in, and the orientation in which they were plugged into each socket. |
