Aller au contenu principal
Démontage du Sony Ericsson S710a
Anglais
Français
Traduction de l’étape 5
Étape 5
Sony Ericsson s710a Teardown: étape 0, image 1 de 1
  • Remove the LCD cable connectors coming from through the hinge hole with a flathead screwdriver.
  • Be sure to record which port each cable was in, including the orientation in which they were plugged into each socket.
  • Now the two parts of the phone are separated.
Retirez les connecteurs du câble LCD provenant du trou de charnière avec un tournevis à tête plate.
IMPORTANT: assurez-vous d'enregistrer le port sur lequel se trouvaient chaque câble et l'orientation sur laquelle ils ont été branchés dans chaque socket.
Maintenant, les deux parties du téléphone sont séparées.
-[* red] Remove the LCD cable connectors coming from through the hinge hole with a flat head screw driver.
-[* icon_note] IMPORTANT: be sure to record which port each cable was in and the orientation they were plugged into each socket.
+[* red] Remove the LCD cable connectors coming from through the hinge hole with a flathead screwdriver.
+ [* icon_reminder] Be sure to record which port each cable was in, including the orientation in which they were plugged into each socket.
[* black] Now the two parts of the phone are separated.
