Aller au contenu principal
Comment souder et dessouder des connexions
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 10
Étape 10
How To Solder and Desolder Connections: étape 0, image 1 de 2 How To Solder and Desolder Connections: étape 0, image 2 de 2
  • Congratulations—you've created a solder joint! Inspect the joint to see if it formed correctly:
  • Leaded solder joints should look like a shiny, concave tent surrounding the entire lead.
  • If the joint isn't shiny, it may not have formed correctly. Reheat the joint briefly and allow it to cool.
  • Lead-free solder joints should look like a concave tent surrounding the entire lead. They may be shiny or dull.
  • If the solder joint doesn't surround the entire lead, reheat the joint and add more solder.
  • If the solder looks like a round bead instead of a concave tent, it didn't bond to the component lead. Reheat the joint and try to get the lead hot enough so the solder bonds to it.
  • Check if any solder unintentionally bridged with a different joint. If so, apply some flux and reheat one of the joints to carefully break the bridge. If the bridge doesn't want to separate follow this step and use solder wick to pull away any extra solder.
  • Like any skill, practice makes perfect. If your first solder joint doesn't look picture-perfect, that's OK! It takes a few attempts to get the hang of the movement and timing.
Félicitations, vous venez de créer un joint de soudure ! Contrôlez le joint pour voir s'il s'est formé correctement :
Les joints de soudure au plomb doivent ressembler à un dôme brillant et concave entourant l'ensemble du plomb.
Si le joint n'est pas brillant, il ne s'est peut-être pas formé correctement. Réchauffez brièvement le joint et laissez-le refroidir.
Les joints de soudure sans plomb doivent ressembler à un dôme concave entourant la totalité du fil. Ils peuvent être brillants ou ternes.
Si le joint de soudure n'entoure pas la totalité du fil, réchauffez le joint et ajoutez de la soudure.
Si la soudure ressemble à un bourrelet rond au lieu d'une tente concave, c'est qu'elle n'a pas adhéré au fil du composant. Réchauffez le joint et essayez de chauffer suffisamment le fil pour que la soudure s'y fixe.
Vérifiez si la soudure n'a pas fait un pont involontaire avec un autre joint. Si c'est le cas, appliquez un peu de flux et réchauffez l'un des joints pour briser soigneusement le pont. Si le pont ne se sépare pas, poursuivez avec cette étape et utilisez une tresse à dessouder pour retirer le surplus de soudure.
Comme pour toute compétence, c'est en forgeant qu'on devient forgeron. Si votre première soudure n'est pas parfaite, ce n'est pas grave ! Il faut quelques tentatives pour maîtriser le mouvement et la synchronisation.
