Outils recommandés dans ce démontage
Introduction
Before you take apart your Free Wheelchair Mission GEN 1 wheelchair familiarize yourself with tools you will be using with the Free Wheelchair Mission Tools Maintenance Guide.
Start by finding the pump on the back of the wheelchair
Remove the screw holding the pump to the frame with a 10mm wrench
Remove the footrest by turning it upside down and use the 10 mm box wrench to take out all four of the screws
Locate the 4 ties around the corners and back of the chair
Untie each of the knots by pulling the strings
Remove the cushion from the chair
Locate brakes on the back of the small frame behind the wheel.
Unscrew the two screws holding the brake to the frame using the 10 mm box wrench
Remove the brake from the frame
Use the 19mm socket wrench to unscrew the axle bolt.
Use 19mm crescent wrench to keep the nut from spinning
Slide the wheel off the frame
Turn the chair around and locate the two base plates that hold the axle to the back of the chair. There are two screws on each of the plates that connect the chair to the axle.
Hold the nut with a 10 mm wrench in one hand. In the other hand, use a wrench to remove the screw.
Locate the screws that hold the back frame, chair, castor wheel, and front frame together. There is one screw on each side of the chair immediately above where the brakes are located.
Remove both of these screws using a 10mm wrench.
Separate the front frame and and the castor wheel from the chair.
