Camera will not turn on
Below are possible reasons for why the camera will not turn on:
Battery is dead
If the camera display screen won’t turn on after pressing the power button, you may have a faulty or dead battery. To replace the battery, refer to Remplacement de la batterie du Fujifilm Endeavor 100ix.
Power Button is not working
If the camera display screen won't turn on after pressing the power button and changing the battery, you may have a faulty power button. To replace the power button, refer to Remplacement du bouton d'alimentation du Fujifilm Endeavor 100ix.
Camera compartment doors are broken
Below are several possible parts that can break and require replacement:
Film door is broken
If the film door is cracked or broken off, you may need to replace the latch and door. To replace the film door, refer to Remplacement du couvercle d'accès à la pellicule du Fujifilm Endeavor 100ix.
Battery door is broken
If the battery door is cracked or broken off, you may need to replace the latch and door. To replace the battery door, refer to Remplacement la trappe d'accès de la batterie du Fujifilm Endeavor 100ix.
Camera won’t change shooting mode
Below is a possible part that can be cleaned:
CHP mode switch is stuck
If the camera will not change shooting mode, the CHP mode switch might be stuck and needs to be unbound. To unbind the CHP mode switch, refer to How to Fujifilm Endeavor 100ix.
0 commentaires
