Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
RC Car Not Turning On
The RC Car fails to turn on and is unresponsive
Recharging the Car Battery
First, remove the battery from the car. Click here to see how to remove the battery. Once the battery is removed, connect the battery into the wall charger provided with the car and connect the charger to the wall outlet. Charge the battery for six hours. Once has been completely recharged, remove it from the charger and connect it to the car. Reinsert the battery to the slot, and close the cover.
Signal Cuts In and Out
The RC car starts and stops driving randomly or while controlling from a far distance
Replacing the Remote Control Battery
Slide open the lid at the bottom of the remote control. Take out the 9V battery. If you have a voltage meter, test the battery to ensure it is dead. If the tester reads less than 7.5 V, then it won’t be able to power the remote. Obtain another 9V battery and follow the voltage testing procedure to make sure it has enough charge to power the controller. If it is fully charged, insert the new 9V battery into the remote control. Note that the positive and negative terminals must be aligned to work.
Increasing Signal Range of Controller
Firmly secure the antenna to the top of the controller be screwing it into the hole found at the top of it. Once securely screwed in, extend the antenna fully for maximum range.
Car Turns When Attempting to Drive Straight
While trying to drive the car in a straight line, the car veers to one side
Alignment Dial is Crooked
Locate the alignment dial between the front wheels. If the dial is not straight, or in line with the car, then adjust the dial accordingly. For example, if the car direction goes left, then adjust the dial to the right side. If it is set straight but fails to drive straight, read on.
Wheels Need Replacing
The steering problem may have nothing to do with the alignment dial. One of the wheels may be defective, causing the car to steer incorrectly. See the Wheel Replacement Guide. If this fails to solve the problem, read on.
Faulty Steering Motor
If the other troubleshooting options fail to work, the motor that controls the steering may be malfunctioning and need replacing. See Replacing the Steering Motor Guide.
Controller Won’t Turn On
The controller light fails to light properly when switching the control on
Controller Battery Dead
See Replacing the Remote Control Battery
One or More Headlights Are Dim or Unlit
One or more headlights are not properly lighting or are dim
The Car as a Whole Fails to Receive Power
Test to see if the car will steer or accelerate. If there is no response, then the car as a whole unit isn’t receiving any power; see Recharging the Car
Dead or Malfunctioning Headlight
If the car is receiving power, then a headlight may have died. See the Replacing a Headlight Guide.
Car Drives at Slow or Inconsistent Speed
Car drives slower than usual or randomly starts and stops even when controller trigger is pressed fully
Weak Signal
Battery is Dead
Faulty Motor
If these don’t solve the problem, then the motor likely needs replacing. See the Replacing the Motor Guide.
Car malfunctions in a variety of ways with no apparent single cause
The car acts sporadically or fails to properly drive
Faulty Motherboard
The motherboard that controls the car’s power, steering, and drive shaft may be malfunctioning, leading to many glitches and unresponsive action in all involved systems. See Replacing the Motherboard Guide.
Un commentaire
Back wheels are not working, do i need to change the motor or the motherboard ?
mmekawtar - Réponse
