Aller au contenu principal
Dell Latitude E5450 Battery Replacement
Ce dont vous avez besoin
  1. Dell Latitude E5450 Battery Replacement, Unscrew the Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Remove the six Philips #0 screws from the lower case.
    • These screws are all 5.6 mm long, but it's still a good idea to keep track of them and make sure they go back in their proper holes!
  2. Dell Latitude E5450 Battery Replacement: étape 2, image 1 de 1
    • This photo shows the location of the ten clips that hold the lower case in place. Take note of the location of the clips, and refer back to this step if your lower case gets stuck during removal.
    • Four clips hold the upper half of the case in place and can be released by prying around them with a spudger.
    • The other six clips along the bottom edge can not be released by prying at them. Instead, they come free by sliding the whole case upward, as shown in step 5 below.
  3. Dell Latitude E5450 Battery Replacement: étape 3, image 1 de 2 Dell Latitude E5450 Battery Replacement: étape 3, image 2 de 2
    • Insert the flat edge of a spudger into the small divot along the top edge of the case, just below the docking station port.
    • Pry up to release the two central clips along the upper edge of the case.
  4. Dell Latitude E5450 Battery Replacement: étape 4, image 1 de 3 Dell Latitude E5450 Battery Replacement: étape 4, image 2 de 3 Dell Latitude E5450 Battery Replacement: étape 4, image 3 de 3
    • Use your spudger to pry up the remaining clips along the top edge.
  5. Dell Latitude E5450 Battery Replacement, Remove the Lower Case: étape 5, image 1 de 3 Dell Latitude E5450 Battery Replacement, Remove the Lower Case: étape 5, image 2 de 3 Dell Latitude E5450 Battery Replacement, Remove the Lower Case: étape 5, image 3 de 3
    • Slide the lower case upward and remove it.
  6. Dell Latitude E5450 Battery Replacement: étape 6, image 1 de 2 Dell Latitude E5450 Battery Replacement: étape 6, image 2 de 2
    • When reinstalling the lower case, make sure you slide the bottom edge (the edge without the cutout) into place first before snapping the rest of the clips shut.
  7. Dell Latitude E5450 Battery Replacement, Disconnect the Battery: étape 7, image 1 de 2 Dell Latitude E5450 Battery Replacement, Disconnect the Battery: étape 7, image 2 de 2
    • Pull up on the battery connector's pull tab to disconnect the battery.
  8. Dell Latitude E5450 Battery Replacement, Unscrew the Battery: étape 8, image 1 de 1
    • Remove the three 5.6 mm Philips #0 screws from the top edge of the battery.
  9. Dell Latitude E5450 Battery Replacement, Remove the Battery: étape 9, image 1 de 3 Dell Latitude E5450 Battery Replacement, Remove the Battery: étape 9, image 2 de 3 Dell Latitude E5450 Battery Replacement, Remove the Battery: étape 9, image 3 de 3
    • Remove the battery from the laptop.
    • The battery cell extends below the bottom lip of the enclosure. Make sure you lift the battery away from the bottom edge of the laptop at an angle, as shown in the photos.
  10. Dell Latitude E5450 Battery Replacement: étape 10, image 1 de 2 Dell Latitude E5450 Battery Replacement: étape 10, image 2 de 2
    • When installing your new battery, slide the bottom edge in first, and make sure it lays flat before you proceed to reinsert the screws or reconnect it.
For optimal performance, calibrate your newly-installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our Dell Latitude Answers community for troubleshooting help.
Taylor Dixon
Membre depuis le 06/26/18
67 188 Réputation
94 tutoriels rédigés
5 commentaires
im in need of dell latitude e5450 motherboard,
nick crider - Réponse
Hi I got my first battery to replace my old one and when I had unboxed it and installed it it didn't turn on so I looked at the back and saw that the back had these 4 squares with there light blue patches cover them and idk if should take them off cause they seem peelable but idk of I should peel them off
Delaney - Réponse
Hi! Please contact our customer support and we will get the issue resolved!
Arthur Shi -
i got error code 2000-0132 after replace the battery
ahmadaufabiljihadi - Réponse
Is a battery type RYXXH compatible with the laptop Dell e5450? even though RYXXH is 11.1 V and the one that it had is 7 V.
Oswal Melean - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 61
Total : 7,021
