Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 9 Pro XL Front Facing Camera Replacement
Ce dont vous avez besoin
  1. Google Pixel 9 Pro XL Front Facing Camera Replacement, Safety precautions: étape 1, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Safety precautions: étape 1, image 2 de 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Demander à FixBot
  2. Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: étape 2, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: étape 2, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: étape 2, image 3 de 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
    Demander à FixBot
  3. Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply a suction handle: étape 3, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply a suction handle: étape 3, image 2 de 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
    Demander à FixBot
  4. Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: étape 4, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: étape 4, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: étape 4, image 3 de 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
    Demander à FixBot
  5. Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: étape 5, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: étape 5, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: étape 5, image 3 de 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    Demander à FixBot
  6. Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 6, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 6, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 6, image 3 de 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
    Demander à FixBot
  7. Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 7, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 7, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 7, image 3 de 3
    • Slide your pick down the right edge to separate the remaining adhesive.
    Demander à FixBot
  8. Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: étape 8, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: étape 8, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: étape 8, image 3 de 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
    Demander à FixBot
  9. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: étape 9, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: étape 9, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
    Demander à FixBot
  10. Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 10, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 10, image 2 de 2
    • Use tweezers or your fingers to remove the cable cover.
    Demander à FixBot
  11. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: étape 11, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: étape 11, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: étape 11, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
    Demander à FixBot
  12. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the rear cover: étape 12, image 1 de 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
    Demander à FixBot
  13. Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: étape 13, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: étape 13, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: étape 13, image 3 de 3
    • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
    • You can completely remove the tape if you want, but be sure to keep it for reassembly.
    Demander à FixBot
  14. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: étape 14, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: étape 14, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
    Demander à FixBot
  15. Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 15, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 15, image 2 de 2
    • Use tweezers or your fingers to remove the cover.
    Demander à FixBot
  16. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the wireless charging assembly: étape 16, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the wireless charging assembly: étape 16, image 2 de 2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
    Demander à FixBot
  17. Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 17, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 17, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 17, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
    Demander à FixBot
  18. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly screws: étape 18, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly screws: étape 18, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
    Demander à FixBot
  19. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly: étape 19, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly: étape 19, image 2 de 2
    • Remove the wireless charging assembly.
    Demander à FixBot
  20. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: étape 20, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: étape 20, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: étape 20, image 3 de 3
    • Use a spudger to pry up and disconnect the battery press connector.
    Demander à FixBot
  21. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover screw: étape 21, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover screw: étape 21, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.2 mm‑long screw securing the mmWave antenna cover.
    Demander à FixBot
  22. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: étape 22, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: étape 22, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: étape 22, image 3 de 3
    • A tight metal clip secures the bottom left corner of the mmWave antenna cover.
    • Insert the point of a spudger under the tab near the bottom left corner of the mmWave antenna cover.
    • Use your spudger to slide the cover to the right while prying up to unclip the cover.
    Demander à FixBot
  23. Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 23, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 23, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: étape 23, image 3 de 3
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
    Demander à FixBot
  24. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: étape 24, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: étape 24, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
    Demander à FixBot
  25. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the front facing camera: étape 25, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the front facing camera: étape 25, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
    Demander à FixBot
  26. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: étape 26, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: étape 26, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: étape 26, image 3 de 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.2 mm‑long screw securing the mmWave antenna.
    Demander à FixBot
  27. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave antenna: étape 27, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave antenna: étape 27, image 2 de 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
    Demander à FixBot
  28. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: étape 28, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: étape 28, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: étape 28, image 3 de 3
    • Light adhesive secures the front facing camera in place.
    • Use the point of a spudger to lift the right edge of the front facing camera, separating its adhesive.
    • Use tweezers or your fingers to remove the camera.
    Demander à FixBot
  29. Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: étape 29, image 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: étape 29, image 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: étape 29, image 3 de 3
    • Use tweezers to remove the old front facing camera adhesive from the frame.
    • Remove the larger clear liner from the front facing camera adhesive.
    • Use tweezers to carefully place the adhesive into the front facing camera recess.
    • Use a spudger to press the adhesive into place, securing it to the frame.
    • Remove the remaining blue liner from the adhesive.
    Demander à FixBot
  30. Google Pixel 9 Pro XL Front Facing Camera Replacement, Install your replacement front camera: étape 30, image 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Install your replacement front camera: étape 30, image 2 de 2
    • Remove any protective caps or liners from your replacement front facing camera.
    • With the cable on the right edge, press the front facing camera into its recess to secure it with the adhesive.
    Demander à FixBot
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membre depuis le 09/14/22
187 930 Réputation
1 187 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
25 707 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 76
Total : 1,126
