Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Huawei Watch 3 Battery Replacement
Ce dont vous avez besoin
    • User your fingernail to pull the small metal pin on each wrist band towards the inside. This unlocks the wrist bands from the body of the watch.
    • Remove the wrist bands.
    Demander à FixBot
    Ajouter un commentaire
  1. Huawei Watch 3 Battery Replacement, Remove the four Torx screws: étape 2, image 1 de 1
    • Use a Torx T3 screwdriver to remove the four 4 mm-long screws on the back of the Huawei Watch 3.
    Demander à FixBot
  2. Huawei Watch 3 Battery Replacement, Pry the back cover open: étape 3, image 1 de 3 Huawei Watch 3 Battery Replacement, Pry the back cover open: étape 3, image 2 de 3 Huawei Watch 3 Battery Replacement, Pry the back cover open: étape 3, image 3 de 3
    • Locate the small notch at the top of the back cover.
    • Use a Jimmy to pry open the back cover by twisting it.
    • Using a sharp metal tool might cause cosmetic damage to the watch case. Covering the tool with a nitril glove can minimize the damage.
    • Don’t remove the back cover just yet. It is still connected to the motherboard with a flex cable.
    Demander à FixBot
  3. Huawei Watch 3 Battery Replacement, Loosen the back cover gasket: étape 4, image 1 de 2 Huawei Watch 3 Battery Replacement, Loosen the back cover gasket: étape 4, image 2 de 2
    • Insert the tip of an opening pick between the back cover and the case.
    • Slide the opening pick around the back cover to loosen the gasket from the back cover.
    Demander à FixBot
  4. Huawei Watch 3 Battery Replacement, Lift the back cover: étape 5, image 1 de 3 Huawei Watch 3 Battery Replacement, Lift the back cover: étape 5, image 2 de 3 Huawei Watch 3 Battery Replacement, Lift the back cover: étape 5, image 3 de 3
    • There is a ribbon cable running from the back cover to the motherboard.
    • Use an opening pick or your fingers to carefully lift the back cover open.
    • Flip the back cover open away from the crown.
    • You can prop up the back cover to minimize the stress on the ribbon cable.
    Demander à FixBot
  5. Huawei Watch 3 Battery Replacement, Remove the battery bracket screw: étape 6, image 1 de 1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the battery bracket.
    Demander à FixBot
  6. Huawei Watch 3 Battery Replacement, Remove the battery bracket: étape 7, image 1 de 3 Huawei Watch 3 Battery Replacement, Remove the battery bracket: étape 7, image 2 de 3 Huawei Watch 3 Battery Replacement, Remove the battery bracket: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    • User a pair of tweezers to lift the top of the battery bracket free from its screw socket.
    • Unhook the opposite side of the bracket and remove it.
    Demander à FixBot
  7. Huawei Watch 3 Battery Replacement, Unplug the battery connector: étape 8, image 1 de 2 Huawei Watch 3 Battery Replacement, Unplug the battery connector: étape 8, image 2 de 2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    • The battery connector is the smallest of the three connectors.
    Demander à FixBot
  8. Huawei Watch 3 Battery Replacement, Remove the sensor bracket screw: étape 9, image 1 de 1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the sensor bracket.
    Demander à FixBot
  9. Huawei Watch 3 Battery Replacement, Remove the sensor bracket: étape 10, image 1 de 3 Huawei Watch 3 Battery Replacement, Remove the sensor bracket: étape 10, image 2 de 3 Huawei Watch 3 Battery Replacement, Remove the sensor bracket: étape 10, image 3 de 3
    • User a pair of tweezers to move the top of the sensor bracket free from a small latch near the case by rotating in inwards.
    Demander à FixBot
  10. Huawei Watch 3 Battery Replacement, Unplug the sensor connector: étape 11, image 1 de 3 Huawei Watch 3 Battery Replacement, Unplug the sensor connector: étape 11, image 2 de 3 Huawei Watch 3 Battery Replacement, Unplug the sensor connector: étape 11, image 3 de 3
    • Use the tip of a spudger to pry up and disconnect the sensor connector.
    • Remove the back cover.
    Demander à FixBot
  11. Huawei Watch 3 Battery Replacement, Disconnect the home button: étape 12, image 1 de 2 Huawei Watch 3 Battery Replacement, Disconnect the home button: étape 12, image 2 de 2
    • Use the tip of a spudger to disconnect the home button cable.
    Demander à FixBot
  12. Huawei Watch 3 Battery Replacement, Lift the battery: étape 13, image 1 de 3 Huawei Watch 3 Battery Replacement, Lift the battery: étape 13, image 2 de 3 Huawei Watch 3 Battery Replacement, Lift the battery: étape 13, image 3 de 3
    • Insert the tip of an opening pick between the battery and the plastic frame opposite to the cables.
    • Use the opening pick to lift the battery up.
    • The battery is held down by mild adhesive.
    Demander à FixBot
  13. Huawei Watch 3 Battery Replacement, Remove the battery: étape 14, image 1 de 2 Huawei Watch 3 Battery Replacement, Remove the battery: étape 14, image 2 de 2
    • Grab the battery with your fingers and remove it.
    • For reassembly you may need to apply some adhesive to the new battery if it does not come equipped with it.
    Demander à FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
133 802 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 145 tutoriels rédigés
5 commentaires de tutoriel
do you know where can i find the back cover for huawei gt3 pro?
Drako Outsgard - Réponse Partager
I want to now //
Hampus Akvist - Réponse Partager
Beste Tobias ik heb een watch 3 waarvan de batterij sneller leegloopt, inmiddels werken de sensors niet meer, dus nieuwe batterij besteld met een toolkit, dat de sensors niet meer werken hoop ik dat door dikker wordende defecte batterij de sensorkabeltje is los gaan zitten, dus duim met me mee dat batterijvervanging de oplossing is en dat het horloge dat in augustus 3 jaar wordt weer leven in wordt geblazen, ik durf zekf vervangen wel aan, prijsopgave Eur 329,00 voor Mediamarkt servicecentrum die motherboard gemujk wil vervangen wegens risico uitnemen batterij
Peter Schmeitz - Réponse Partager
You can do it, Peter–I believe in you.
As long as you are careful with the short cables when opening. Those brackets inside have nifty little hooks, look closely at the images and read the text, this way you’ll be safe.
Keep my fingers crossed for you :)
Tobias Isakeit - Réponse Partager
Hallo Tobias!
Ich bin so froh, dass ich Euch gefunden habe. Ich schraube gerne und möchte, wenn es nur geht kaputte Dinge nicht wegschmeißen.
Dieser Akkuwechsel wird mich mal wieder auf die Probe stellen.
Dank für Deine sehr guter Beschreibung Tobias, bin ich sehr zuversichtlich.
Muss allerdings tief Luft Holen.
Wie es ausgegangen ist werde ich berichten.
LG
Csaba
Dr. Csaba Tatai - Réponse Partager
Nombre de vues :
Dernières 24 heures : 20
7 derniers jours : 84
30 derniers jours : 476
Total : 24,420
