Aller au contenu principal
MacBook Air 13" Early 2020 Logic Board Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Early 2020 Logic Board Replacement, Remove the screws securing the lower case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Early 2020 Logic Board Replacement, Remove the lower case: étape 2, image 1 de 3 MacBook Air 13" Early 2020 Logic Board Replacement, Remove the lower case: étape 2, image 2 de 3 MacBook Air 13" Early 2020 Logic Board Replacement, Remove the lower case: étape 2, image 3 de 3
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Early 2020 Logic Board Replacement, Disconnect the battery: étape 3, image 1 de 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Early 2020 Logic Board Replacement: étape 4, image 1 de 2 MacBook Air 13" Early 2020 Logic Board Replacement: étape 4, image 2 de 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Early 2020 Logic Board Replacement, Disconnect the logic board: étape 5, image 1 de 2 MacBook Air 13" Early 2020 Logic Board Replacement, Disconnect the logic board: étape 5, image 2 de 2
    • Use a T4 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
    • Remove the trackpad cable cover.
  6. MacBook Air 13" Early 2020 Logic Board Replacement: étape 6, image 1 de 2 MacBook Air 13" Early 2020 Logic Board Replacement: étape 6, image 2 de 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  7. MacBook Air 13" Early 2020 Logic Board Replacement: étape 7, image 1 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 7, image 2 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 7, image 3 de 3
    • The left speaker will be on your righthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  8. MacBook Air 13" Early 2020 Logic Board Replacement: étape 8, image 1 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 8, image 2 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 8, image 3 de 3
    • Use a pair of tweezers to peel back any tape covering the microphone cable connector.
    • Use the pointed end of a spudger to lift up the small locking flap on the microphone cable's ZIF connector.
    • Slide the microphone cable out of its connector.
    • If possible, grip the cable by the tape, not by the cable itself.
  9. MacBook Air 13" Early 2020 Logic Board Replacement: étape 9, image 1 de 2 MacBook Air 13" Early 2020 Logic Board Replacement: étape 9, image 2 de 2
    • Use a T4 Torx driver to remove the two 1.4 mm screws securing the USB-C connector cover.
    • Remove the USB-C connector cover.
  10. MacBook Air 13" Early 2020 Logic Board Replacement: étape 10, image 1 de 2 MacBook Air 13" Early 2020 Logic Board Replacement: étape 10, image 2 de 2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  11. MacBook Air 13" Early 2020 Logic Board Replacement: étape 11, image 1 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 11, image 2 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 11, image 3 de 3
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  12. MacBook Air 13" Early 2020 Logic Board Replacement: étape 12, image 1 de 1
    • Peel back the black tape covering the fan cable connector.
  13. MacBook Air 13" Early 2020 Logic Board Replacement: étape 13, image 1 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 13, image 2 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 13, image 3 de 3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  14. MacBook Air 13" Early 2020 Logic Board Replacement: étape 14, image 1 de 2 MacBook Air 13" Early 2020 Logic Board Replacement: étape 14, image 2 de 2
    • Use a T4 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
    • Remove the antenna cable cover.
  15. MacBook Air 13" Early 2020 Logic Board Replacement: étape 15, image 1 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 15, image 2 de 3 MacBook Air 13" Early 2020 Logic Board Replacement: étape 15, image 3 de 3
    • Use a pair of tweezers to grip the antenna connector close to its base.
    • Pull straight up to disconnect the cable.
    • Repeat for the second antenna cable.
  16. MacBook Air 13" Early 2020 Logic Board Replacement: étape 16, image 1 de 2 MacBook Air 13" Early 2020 Logic Board Replacement: étape 16, image 2 de 2
    • Use a T4 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
    • Remove the display cable connector cover.
  17. MacBook Air 13" Early 2020 Logic Board Replacement: étape 17, image 1 de 2 MacBook Air 13" Early 2020 Logic Board Replacement: étape 17, image 2 de 2
    • Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
  18. MacBook Air 13" Early 2020 Logic Board Replacement, Remove the logic board screws: étape 18, image 1 de 1
    • Use a T5 Torx driver to remove the six screws securing the logic board to the upper case:
    • Three 3.5 mm screws
    • One 5.8 mm cushioned screw
    • Two 2.0 mm screws
  19. MacBook Air 13" Early 2020 Logic Board Replacement, Remove the logic board: étape 19, image 1 de 1
    • Remove the logic board.
  20. MacBook Air 13" Early 2020 Logic Board Replacement, Check cables during reassembly: étape 20, image 1 de 1
    • When you reinstall the logic board assembly, verify that no cables get trapped under the board as you lower it into place. Check each of the seven locations carefully:
    • Battery cable
    • Fan cable
    • Audio board cable
    • USB-C board cable
    • Antenna bar cables
    • Trackpad cable
    • Left speaker and microphone cables
10 autres ont terminé cette réparation.
Carsten Frauenheim
Membre depuis le 03/10/20
114 056 Réputation
338 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 198 tutoriels rédigés
Un commentaire
donde se ubica disco duro , ya que ledi opcion borrar mac y maraca error desde recovery
daniel ortiz salazar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 150
30 derniers jours : 661
Total : 23,712
