Introduction
This guide takes some time to complete and will not void your OnePlus 5's warranty. It is recommended to store the screws and parts together with their corresponding step in the guide to lower the chance of lost parts. No special skills are required for this guide.
Always make sure to turn off the phone before attempting to replace a part.
  • Always make sure to turn off the phone before attempting to replace a part.
  • Power off the phone by holding down the rectangular power button on right side and pressing the red button that says "Power off."
Ajouter un commentaire
Remove the two 1mm Torx #2 screws at the bottom of the phone by rotating the screwdriver counter-clockwise. Remove the two 1mm Torx #2 screws at the bottom of the phone by rotating the screwdriver counter-clockwise.
  • Remove the two 1mm Torx #2 screws at the bottom of the phone by rotating the screwdriver counter-clockwise.
Locate the sim card on the right side of the phone. Insert the SIM ejector screwdriver bit into the hole left of the sim card holder by applying pressure. It is also okay to use the SIM card eject tool for this step.
  • Locate the sim card on the right side of the phone.
  • Insert the SIM ejector screwdriver bit into the hole left of the sim card holder by applying pressure.
  • It is also okay to use the SIM card eject tool for this step.
  • Remove the sim card holder by pulling it out with your fingers.
Insert the plastic iFixit opening tool  between the the plastic rim of the screen and the metal edge of the phone. Place a suction cup on the screen to gain more leverage when separating the screen from the back plate. Moving right to left around the phone, carefully pry the screen away from the back plate by wiggling the iFixit opening tool and pulling the suction cup in the opposite direction.
  • Insert the plastic iFixit opening tool between the the plastic rim of the screen and the metal edge of the phone.
  • Place a suction cup on the screen to gain more leverage when separating the screen from the back plate.
  • Moving right to left around the phone, carefully pry the screen away from the back plate by wiggling the iFixit opening tool and pulling the suction cup in the opposite direction.
  • When reassembling, apply pressure to the edges of the screen and back plate together until they pop back into place.
Locate the metal connector cap on the upper half of the device directly above the battery. Remove the 1mm Phillips #0 screw from the metal connector cap by rotating the screwdriver counter-clockwise. Remove the 1mm Phillips #0 screw from the metal connector cap by rotating the screwdriver counter-clockwise.
  • Locate the metal connector cap on the upper half of the device directly above the battery.
  • Remove the 1mm Phillips #0 screw from the metal connector cap by rotating the screwdriver counter-clockwise.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Carefully pop out the metal connector cap with the nylon spudger and remove it by pulling up. Carefully pop out the metal connector cap with the nylon spudger and remove it by pulling up.
  • Carefully pop out the metal connector cap with the nylon spudger and remove it by pulling up.
Locate the two connectors directly above the battery on the left side of the device. Remove the battery connector cable located to the right of the charging port connector cable using a nylon spudger by prying underneath it and popping it up. Remove the charging port connector cable to the left of the battery cable using a nylon spudger by prying underneath it and popping it up.
  • Locate the two connectors directly above the battery on the left side of the device.
  • Remove the battery connector cable located to the right of the charging port connector cable using a nylon spudger by prying underneath it and popping it up.
  • Remove the charging port connector cable to the left of the battery cable using a nylon spudger by prying underneath it and popping it up.
Remove the six 1mm Phillips #0 screws by rotating the screwdriver counter-clockwise. Remove the six 1mm Phillips #0 screws by rotating the screwdriver counter-clockwise. Remove the six 1mm Phillips #0 screws by rotating the screwdriver counter-clockwise.
  • Remove the six 1mm Phillips #0 screws by rotating the screwdriver counter-clockwise.
Remove the loudspeaker by gently pushing the spudger underneath it and prying it out. Remove the loudspeaker by gently pushing the spudger underneath it and prying it out. Remove the loudspeaker by gently pushing the spudger underneath it and prying it out.
  • Remove the loudspeaker by gently pushing the spudger underneath it and prying it out.
Notice the cable that goes across the yellow battery from the top to the bottom. There is a connector for this cable at the bottom of the battery. Remove this cable by pushing a spudger underneath the connector and popping it out. Remove this cable by pushing a spudger underneath the connector and popping it out.
  • Notice the cable that goes across the yellow battery from the top to the bottom. There is a connector for this cable at the bottom of the battery.
  • Remove this cable by pushing a spudger underneath the connector and popping it out.
Notice the two clear adhesive flaps overlapping on the left and right side of the yellow battery. Peel back these flaps by running the spudger between the the flaps and battery, seperating the adhesive. When reassembling the device, the spudger is not needed. Fold the flaps over so that the sticky side touches the yellow battery and connect the adhesive.
  • Notice the two clear adhesive flaps overlapping on the left and right side of the yellow battery.
  • Peel back these flaps by running the spudger between the the flaps and battery, seperating the adhesive.
  • When reassembling the device, the spudger is not needed. Fold the flaps over so that the sticky side touches the yellow battery and connect the adhesive.
  • Be careful not to push too hard with the nylon spudger as you may pierce the battery and release toxic chemicals.
Remove the yellow battery by pulling up and to the left on the green pull-tab. This will create a ripping sound. This is because of the adhesive on the back of the battery and is completely normal. This will create a ripping sound. This is because of the adhesive on the back of the battery and is completely normal.
  • Remove the yellow battery by pulling up and to the left on the green pull-tab.
  • This will create a ripping sound. This is because of the adhesive on the back of the battery and is completely normal.
Remove the seven 1mm Phillips #0 screws by rotating screwdriver counter clockwise. Remove the earpiece speaker connector located on the top of the motherboard using a nylon spudger by prying underneath it. Remove the LCD screen connector located on the bottom of the motherboard using a nylon spudger by prying underneath it.
  • Remove the seven 1mm Phillips #0 screws by rotating screwdriver counter clockwise.
  • Remove the earpiece speaker connector located on the top of the motherboard using a nylon spudger by prying underneath it.
  • Remove the LCD screen connector located on the bottom of the motherboard using a nylon spudger by prying underneath it.
  • Disconnect the antenna wire located on the right side of the motherboard using a nylon spudger by prying underneath it.
  • The antenna wire will be clipped onto the motherboard so make sure it is fully unclipped before removing the motherboard.
Remove the motherboard by gently pushing the spudger underneath upper right hand corner of the motherboard and prying it out. Remove the motherboard by gently pushing the spudger underneath upper right hand corner of the motherboard and prying it out. Remove the motherboard by gently pushing the spudger underneath upper right hand corner of the motherboard and prying it out.
  • Remove the motherboard by gently pushing the spudger underneath upper right hand corner of the motherboard and prying it out.
2 autre(s) ont terminé cette réparation.
Jose Velazquez
Membre depuis le 24/01/2018
459 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S19-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S19-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G1
4 membres
7 tutoriels rédigés
Nice. But where do you get the replacement part from?
Christos Mantas - Réponse
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 58
30 derniers jours : 289
Total : 853
