Aller au contenu principal
Removing factory feet from a Mac Laptop (Non-Retina)
Ce dont vous avez besoin
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: étape 1, image 1 de 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: étape 1, image 2 de 2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: étape 2, image 1 de 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: étape 2, image 2 de 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: étape 2, image 3 de 3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: étape 3, image 1 de 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: étape 3, image 2 de 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    iFixit Opening Picks (Set of 6)
    J'achète
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: étape 4, image 1 de 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: étape 4, image 2 de 2
    Adhesive Cleanup Kit (Set of 12)
    J'achète
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Ligne d'arrivée
4 autres ont terminé cette réparation.
Nick
Membre depuis le 11/10/09
88 887 Réputation
49 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 536 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 17
30 derniers jours : 56
Total : 4,370
