Aller au contenu principal
Samsung Galaxy S22 Plus Back Cover Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S22 Plus Back Cover Replacement, Heat the bottom edge: étape 1, image 1 de 1
    • Prepare an iOpener and apply it to the bottom edge of the back cover for three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S22 Plus Back Cover Replacement, Insert an opening pick: étape 2, image 1 de 3 Samsung Galaxy S22 Plus Back Cover Replacement, Insert an opening pick: étape 2, image 2 de 3 Samsung Galaxy S22 Plus Back Cover Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to dry so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Samsung Galaxy S22 Plus Back Cover Replacement, Slice the bottom adhesive: étape 3, image 1 de 3 Samsung Galaxy S22 Plus Back Cover Replacement, Slice the bottom adhesive: étape 3, image 2 de 3 Samsung Galaxy S22 Plus Back Cover Replacement, Slice the bottom adhesive: étape 3, image 3 de 3
    • Remove the suction handle.
    • Slide the opening pick along the bottom edge to slice the adhesive.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Leave the opening pick inserted near the bottom left corner to prevent the adhesive from resealing.
  4. Samsung Galaxy S22 Plus Back Cover Replacement, Heat the left edge: étape 4, image 1 de 1
    • Apply the heated iOpener to the left edge of the phone for 3 minutes to soften the adhesive.
    • Reheat your iOpener for 30 seconds if necessary.
    • Be careful not to overheat the iOpener. Overheating may cause the iOpener to burst.
    • A properly heated iOpener should stay warm for up to 10 minutes.
  5. Samsung Galaxy S22 Plus Back Cover Replacement, Slice the left adhesive: étape 5, image 1 de 3 Samsung Galaxy S22 Plus Back Cover Replacement, Slice the left adhesive: étape 5, image 2 de 3 Samsung Galaxy S22 Plus Back Cover Replacement, Slice the left adhesive: étape 5, image 3 de 3
    • Insert a second opening pick into the gap created near the bottom left corner.
    • Don't insert the opening pick more than 5 mm, or you risk damaging cables near the camera module.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick inserted near the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S22 Plus Back Cover Replacement: étape 6, image 1 de 1
    • Apply your heated iOpener to the right edge of the phone for 3 minutes to soften the adhesive.
  7. Samsung Galaxy S22 Plus Back Cover Replacement: étape 7, image 1 de 3 Samsung Galaxy S22 Plus Back Cover Replacement: étape 7, image 2 de 3 Samsung Galaxy S22 Plus Back Cover Replacement: étape 7, image 3 de 3
    • Insert a third opening pick into the gap created along the bottom edge.
    • Slide the opening pick around the bottom right corner of the back cover to slice the adhesive.
  8. Samsung Galaxy S22 Plus Back Cover Replacement: étape 8, image 1 de 2 Samsung Galaxy S22 Plus Back Cover Replacement: étape 8, image 2 de 2
    • Continue sliding the opening pick up along the right edge of the back cover to slice the adhesive.
    • Don't insert the opening pick more than 5 mm to avoid damaging any internal components.
    • Leave the opening pick inserted near the top right corner to prevent the adhesive from resealing.
  9. Samsung Galaxy S22 Plus Back Cover Replacement: étape 9, image 1 de 1
    • Apply your heated iOpener to the top edge of the phone for 3 minutes to soften the adhesive.
  10. Samsung Galaxy S22 Plus Back Cover Replacement: étape 10, image 1 de 3 Samsung Galaxy S22 Plus Back Cover Replacement: étape 10, image 2 de 3 Samsung Galaxy S22 Plus Back Cover Replacement: étape 10, image 3 de 3
    • Slide the opening pick in the top left corner across the top edge to separate the remaining adhesive.
    • Don't insert the pick more than 5 mm to avoid damaging or smearing the rear cameras and flash.
  11. Samsung Galaxy S22 Plus Back Cover Replacement: étape 11, image 1 de 2 Samsung Galaxy S22 Plus Back Cover Replacement: étape 11, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
Sam Omiotek
Membre depuis le 02/25/19
73 693 Réputation
288 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 30
30 derniers jours : 148
Total : 2,571
