Aller au contenu principal
iPad mini 5 Wi-Fi Power Button Cable Replacement
Ce dont vous avez besoin
  1. iPad mini 5 Wi-Fi Power Button Cable Replacement, Apply tape to a cracked screen: étape 1, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement, Apply tape to a cracked screen: étape 1, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement, Apply tape to a cracked screen: étape 1, image 3 de 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad mini 5 Wi-Fi Power Button Cable Replacement, Opening Procedure: étape 2, image 1 de 1
  3. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 3, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 3, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 3, image 3 de 3
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  4. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 4, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 4, image 2 de 2
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  5. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 5, image 1 de 1
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  6. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 6, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 6, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 6, image 3 de 3
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  7. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 7, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 7, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 7, image 3 de 3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  8. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 8, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 8, image 2 de 2
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  9. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 9, image 1 de 1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  10. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 10, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 10, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 10, image 3 de 3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  11. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 11, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 11, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 11, image 3 de 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  12. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 12, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 12, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 12, image 3 de 3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  13. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 13, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 13, image 2 de 2
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  14. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 14, image 1 de 1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  15. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 15, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 15, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 15, image 3 de 3
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  16. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 16, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 16, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 16, image 3 de 3
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  17. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 17, image 1 de 1
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  18. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 18, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 18, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 18, image 3 de 3
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  19. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 19, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 19, image 2 de 2
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  20. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 20, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 20, image 2 de 2
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  21. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 21, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 21, image 2 de 2
    • Slide the pick around the lower left edge of the iPad.
  22. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 22, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 22, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 22, image 3 de 3
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  23. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 23, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 23, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 23, image 3 de 3
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  24. iPad mini 5 Wi-Fi Power Button Cable Replacement, Hold the screen perpendicular: étape 24, image 1 de 1
    • To avoid stressing any cables, hold the screen perpendicular to the frame.
  25. iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the display cable bracket: étape 25, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Continue to hold the screen perpendicular during this step.
    • Use a Phillips screwdriver to remove the two 1.3 mm screws securing the display cable bracket.
  26. iPad mini 5 Wi-Fi Power Button Cable Replacement, Reposition the screen: étape 26, image 1 de 1
    • You'll need to reposition the screen to access the bottom side of the display cable bracket.
    • Lower the screen to about 30 degrees above the frame.
  27. iPad mini 5 Wi-Fi Power Button Cable Replacement, Disconnect the battery: étape 27, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Disconnect the battery: étape 27, image 2 de 2
    • The battery press connector is attached to the underside of the display cable bracket on the screw hole side.
    • Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Don't try to remove the display cable bracket as it's attached to the battery by the battery cable.
  28. iPad mini 5 Wi-Fi Power Button Cable Replacement, Rotate the display cable bracket: étape 28, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement, Rotate the display cable bracket: étape 28, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement, Rotate the display cable bracket: étape 28, image 3 de 3
    • The display cable bracket is secured by a clip under the edge of the frame.
    • Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
    • Rotate the display cable bracket toward the battery.
    • Don't bend the battery cable too much past vertical to avoid damaging it. You only need enough space to disconnect the display press connectors and prevent the battery connector from making contact with its socket during the repair.
  29. iPad mini 5 Wi-Fi Power Button Cable Replacement, Disconnect the display press connectors: étape 29, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Disconnect the display press connectors: étape 29, image 2 de 2
    • Use the pointed end of a spudger to disconnect the digitizer press connector from the logic board.
  30. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 30, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 30, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 30, image 3 de 3
    • Use the pointed end of a spudger to disconnect the second and third display press connectors.
  31. iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the screen: étape 31, image 1 de 1
    • Lift and remove the screen.
  32. iPad mini 5 Wi-Fi Power Button Cable Replacement, Screen reassembly information: étape 32, image 1 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement, Screen reassembly information: étape 32, image 2 de 3 iPad mini 5 Wi-Fi Power Button Cable Replacement, Screen reassembly information: étape 32, image 3 de 3
    • During reassembly, remove any remaining adhesive and residue from the perimeters of the frame and the screen. Then, apply new adhesive to secure the screen to the frame.
    • Don't remove the black tape on the left, right, and upper edges of the display. These hold the display to the front glass.
    • Follow this guide if you are using a pre-cut adhesive card. Follow this guide if you are using custom-cut adhesives.
  33. iPad mini 5 Wi-Fi Power Button Cable Replacement, Lift the tape: étape 33, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Lift the tape: étape 33, image 2 de 2
    • Use a pair of tweezers to lift up the tape covering the press connector cover screws.
    • Lift the tape slowly to avoid ripping it. You can pry it off of the press connector cover by pulling it up in multiple places if needed.
  34. iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the three Phillips screws: étape 34, image 1 de 1
    • Use a Phillips screwdriver to remove the three screws securing the press connector cover:
    • One 1.9 mm screw
    • Two 1.3 mm screws
  35. iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the press connector cover: étape 35, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the press connector cover: étape 35, image 2 de 2
    • Use a pair of tweezers to remove the press connector cover.
  36. iPad mini 5 Wi-Fi Power Button Cable Replacement, Disconnect the rear facing camera: étape 36, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Disconnect the rear facing camera: étape 36, image 2 de 2
    • Use the pointed end of a spudger to disconnect the rear facing camera press connector.
  37. iPad mini 5 Wi-Fi Power Button Cable Replacement, Loosen the rear facing camera: étape 37, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Loosen the rear facing camera: étape 37, image 2 de 2
    • Apply one or two drops of high-concentration (90% or higher) isopropyl alcohol around the perimeter of the rear facing camera.
    • Wait two minutes for the isopropyl alcohol to weaken the adhesive underneath the rear facing camera.
    • Alternatively, you can heat an iOpener and apply it to the top left corner of the rear cover for two minutes to weaken the adhesive securing the rear facing camera.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the internal battery is susceptible to heat damage.
  38. iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the rear facing camera: étape 38, image 1 de 1
    • Use a pair of tweezers to lift and remove the rear facing camera.
    • If you are going to reuse the original rear facing camera, take care not to damage the lens or the ribbon cable adhered to its sides.
    • If there's any alcohol solution remaining in the device, carefully wipe it off or allow it to air dry before installing your new rear facing camera.
    • During reassembly, remove any remaining adhesive and residue before applying new adhesive and installing the rear facing camera.
    • Follow this guide if you are using a pre-cut adhesive.
    • Follow this guide if you are using custom-cut adhesives for your device.
  39. iPad mini 5 Wi-Fi Power Button Cable Replacement, Disconnect the power button: étape 39, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Disconnect the power button: étape 39, image 2 de 2
    • Use the pointed end of a spudger to disconnect the power button press connector.
  40. iPad mini 5 Wi-Fi Power Button Cable Replacement, Pull the power button cable out: étape 40, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Pull the power button cable out: étape 40, image 2 de 2
    • Use a pair of tweezers to pull the power button cable out from under the shelf.
  41. iPad mini 5 Wi-Fi Power Button Cable Replacement, Power button cable adhesive information: étape 41, image 1 de 1
    • The power button cable is secured to the shelf with light adhesive.
    • The are two pegs aligning the power button cable. They are located near the lower and upper edges of the shelf. Work around these pegs as you cut through the adhesive.
  42. iPad mini 5 Wi-Fi Power Button Cable Replacement, Detach the power button cable: étape 42, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Detach the power button cable: étape 42, image 2 de 2
    • Use an opening pick cut through the adhesive under the power button cable and detach it from the shelf.
  43. iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the two screws securing the bracket: étape 43, image 1 de 1
    • Use a Phillips screwdriver to remove the two 4.2 mm screws securing the power button bracket.
  44. iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the power button bracket: étape 44, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the power button bracket: étape 44, image 2 de 2
    • Use a pair of tweezers to remove the power button bracket.
  45. iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the power button cable from the bracket: étape 45, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement, Remove the power button cable from the bracket: étape 45, image 2 de 2
    • Use an opening pick to cut through the adhesive securing the power button cable to the bracket.
  46. iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 46, image 1 de 2 iPad mini 5 Wi-Fi Power Button Cable Replacement: étape 46, image 2 de 2
    • Remove the power button cable from the bracket.
    • To install a new power button cable:
    • Remove any remaining adhesive and residue from the bracket.
    • If your part doesn't come with adhesive preinstalled:
    • Place the power button cable onto the bracket and press firmly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 5 Answers community for help.
2 autres ont terminé cette réparation.
Kyle Smith
Membre depuis le 02/01/21
40 974 Réputation
123 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 80
Total : 1,831
