Aller au contenu principal
iPhone SE 2022 Earpiece Speaker Replacement
Ce dont vous avez besoin
  1. iPhone SE 2022 Earpiece Speaker Replacement, Remove the pentalobe screws: étape 1, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Remove the pentalobe screws: étape 1, image 2 de 2
    • Power off your phone before beginning disassembly.
    • Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
  2. iPhone SE 2022 Earpiece Speaker Replacement, Mark your opening picks: étape 2, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Mark your opening picks: étape 2, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Mark your opening picks: étape 2, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone SE 2022 Earpiece Speaker Replacement, Tape over any cracks: étape 3, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Tape over any cracks: étape 3, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Tape over any cracks: étape 3, image 3 de 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone SE 2022 Earpiece Speaker Replacement, Anti-Clamp instructions: étape 4, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Anti-Clamp instructions: étape 4, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Anti-Clamp instructions: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone SE 2022 Earpiece Speaker Replacement: étape 5, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement: étape 5, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement: étape 5, image 3 de 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone SE 2022 Earpiece Speaker Replacement: étape 6, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement: étape 6, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement: étape 6, image 3 de 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone SE 2022 Earpiece Speaker Replacement, Heat the front panel adhesive: étape 7, image 1 de 1
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  8. iPhone SE 2022 Earpiece Speaker Replacement, Insert an opening pick: étape 8, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Insert an opening pick: étape 8, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Insert an opening pick: étape 8, image 3 de 3
    • Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
    • Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
    • If you have trouble creating a gap, apply more heat to the bottom half of the screen to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap under the screen's plastic bezel.
  9. iPhone SE 2022 Earpiece Speaker Replacement, Slice the adhesive: étape 9, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Slice the adhesive: étape 9, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Slice the adhesive: étape 9, image 3 de 3
    • Slide the opening pick to the bottom right corner to slice the front panel adhesive.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  10. iPhone SE 2022 Earpiece Speaker Replacement, Slice the adhesive: étape 10, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Slice the adhesive: étape 10, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Slice the adhesive: étape 10, image 3 de 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  11. iPhone SE 2022 Earpiece Speaker Replacement: étape 11, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement: étape 11, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement: étape 11, image 3 de 3
    • Slide the bottom right opening pick along the right edge of your phone to slice the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Stop near the top right corner of the display.
  12. iPhone SE 2022 Earpiece Speaker Replacement, Lift the screen: étape 12, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Lift the screen: étape 12, image 2 de 2
    • Remove the opening picks.
    • Gently pull up on the suction handle to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Remove the suction handle.
  13. iPhone SE 2022 Earpiece Speaker Replacement, Slice the remaining adhesive: étape 13, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Slice the remaining adhesive: étape 13, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Slice the remaining adhesive: étape 13, image 3 de 3
    • Slide an opening pick underneath the top left corner of the display.
    • Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
  14. iPhone SE 2022 Earpiece Speaker Replacement, Disengage the front panel clips: étape 14, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Disengage the front panel clips: étape 14, image 2 de 2
    • Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
  15. iPhone SE 2022 Earpiece Speaker Replacement, Lift up the display: étape 15, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Lift up the display: étape 15, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Lift up the display: étape 15, image 3 de 3
    • Open the phone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display from the phone assembly yet, as several fragile ribbon cables still connect it to the logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone SE 2022 Earpiece Speaker Replacement, Unfasten the lower display cable bracket screws: étape 16, image 1 de 1
    Magnetic Project Mat
    $19.95
    J'achète
    • Remove the four Phillips screws securing the lower display cable bracket:
    • Two 1.2 mm-long screws
    • Two 2.8 mm-long screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  17. iPhone SE 2022 Earpiece Speaker Replacement, Remove the lower display cable bracket: étape 17, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Remove the lower display cable bracket: étape 17, image 2 de 2
    • Use a pair of tweezers to carefully remove the lower display cable bracket.
  18. iPhone SE 2022 Earpiece Speaker Replacement, Disconnect the battery: étape 18, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Disconnect the battery: étape 18, image 2 de 2
    • Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
  19. iPhone SE 2022 Earpiece Speaker Replacement, Disconnect the display and digitizer cables: étape 19, image 1 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Disconnect the display and digitizer cables: étape 19, image 2 de 3 iPhone SE 2022 Earpiece Speaker Replacement, Disconnect the display and digitizer cables: étape 19, image 3 de 3
    • The display and digitizer cables run on top of each other. To avoid cable damage always start by disconnecting the upper cable first and never try to disconnect both at the same time.
    • Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
    • To re-attach press connectors like this, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  20. iPhone SE 2022 Earpiece Speaker Replacement, Unfasten the front sensor assembly bracket screws: étape 20, image 1 de 1
    • Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
  21. iPhone SE 2022 Earpiece Speaker Replacement, Remove the front sensor assembly bracket: étape 21, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Remove the front sensor assembly bracket: étape 21, image 2 de 2
    • Use a pair of tweezers to carefully remove the front sensor assembly bracket.
  22. iPhone SE 2022 Earpiece Speaker Replacement, Disconnect the front sensor assembly cable: étape 22, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Disconnect the front sensor assembly cable: étape 22, image 2 de 2
    • Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
  23. iPhone SE 2022 Earpiece Speaker Replacement, Remove the display assembly: étape 23, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Remove the display assembly: étape 23, image 2 de 2
    • Remove the display assembly.
  24. iPhone SE 2022 Earpiece Speaker Replacement, Unfasten the earpiece speaker bracket screws: étape 24, image 1 de 1
    • Unfasten the three screws securing the earpiece speaker bracket:
    • Two 2.6 mm-long Phillips screws
    • One 1.6 mm-long Phillips screw
  25. iPhone SE 2022 Earpiece Speaker Replacement, Remove the earpiece speaker bracket: étape 25, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Remove the earpiece speaker bracket: étape 25, image 2 de 2
    • Use a pair of tweezers to carefully remove the earpiece speaker bracket.
  26. iPhone SE 2022 Earpiece Speaker Replacement, Free the earpiece speaker: étape 26, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Free the earpiece speaker: étape 26, image 2 de 2
    • Use a pair of tweezers to lift the front facing camera out of its socket and swing it to the left to get free access to the earpiece speaker.
    • Avoid straining the front camera cable during this procedure.
  27. iPhone SE 2022 Earpiece Speaker Replacement, Unfasten the earpiece speaker screws: étape 27, image 1 de 1
    • Unfasten the two screws securing the earpiece speaker:
    • One 1.8 mm-long Phillips screw
    • One 2.3 mm-long Phillips screw
  28. iPhone SE 2022 Earpiece Speaker Replacement, Remove the earpiece speaker: étape 28, image 1 de 2 iPhone SE 2022 Earpiece Speaker Replacement, Remove the earpiece speaker: étape 28, image 2 de 2
    • Use a pair of tweezers to remove the earpiece speaker.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Dominik Schnabelrauch
Membre depuis le 11/23/16
203 728 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 182 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 35
30 derniers jours : 147
Total : 2,340
