Thank you for trying to help and sorry I answer so late!
I did put the Tiger retail disk in and chose "install" (did not choose "archieve and install"), if you mean that. I had a clean install after that, with no upgrades and no additional things added.
I think you do not understand me. I am foreign, but I did not know, that my english was so bad, so sorry. I think I have to explain it once again.
I did NOT know, that this particular drive is known for errors! I said that I think that one WOULD have heard of this drive causing problems in forums (like macrumors and others). Translation: if the Drive was famous for being @@%^, I should have read this in forums.
Second thing I must have explained in a misleading way: My drive is spinning up right and the OS works ok! It does fully load! The Disk Utility does not find any errors! Translation: my drive does not click and it is not dead. Dead meaning, that it does not move anymore, because the motor is defective.
In an additional attempt I used a fresh drive via firewire (like I mentioned before) and the Problem was still there (again, my problem is, that the OS goes into shut down instead of sleep and I have to unplug everything to get it alive again. If I disable sleep mode in energy savings and "stop disk if possible", everything is ok).
I am sorry my English is so bad and hope you can help me easier with the clarifications I made.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
Are you loosing the date & time? if not your PRAM battery is OK. I don't think its the cause of your problem in either case. HAve you tried resetting the PRAM as well as check if your OS is OK?
par Dan
Thank you!
As I wrote: "New install of OS 10.4.11 didn't solve the problem."
I do not loose date and time, if I do unplug and put back the charging battery and power-cable quick enough.
Did PRAM reset, of course, too.
I should mention, I have installed a WWD3200BEVE, but I think one would have heard of it, if it was this special model causing the problem. I also do not know, if the sleep-problem was already there before the HDD change.
PS: does someone know a sata-ide adapter that would fit in an ibook G4 12" 1,33GHz (last 2005), to use a sata disk?
par apfel
Did you reformat the HD or just refresh the OS? You may need to reformat the HD to solve this problem.
As you commented on having one of the known problem Western Digital HD's that also could be a factor here. Here's a vid on the WD hard drive failure Clicking HD This is when it no longer spins up as the spindle motor has ceased.
Do you have a fresh drive you can use here instead of this one?
par Dan
