Can I replace with a different speed logic board?
Does anyone know if I can replace a Macbook logic board with a different speed one? I have a 2.1, but not many available at a good price. I can get other speeds for decent price.
Is this possible / advisable /reasonable?
Macbook Early 2008 A1181 2.1 Ghz Core 2 Duo
Thanks!
Update
Hi Dan;
The system I'm working on is inop., with a bad logic board.
It's not a question of performance. I'm very familiar with that side of the issue - no problem with that. At this point it's a matter of availability and the possibility of physically putting in a different board. Given your info, I'll probably hold out for a direct replacement.
Thank you.
Tim
2 commentaires
If you stick within the series you should be fine. Tip: look at the everymac web site for the systems that came out around the same time. These should all fit and work.
par Dan
Found a direct replacement board - 2.1 ghz. Will likely add secend drive and/or SSD and max out RAM as usual.
Thanks!
par tjod
