Keyboard on Permanent Repeat - stuck keys?!
Hello.
My A1260 MBP seems to periodically have an issue where the space bar will act like it is being pressed down when in actuality it is not. It makes a repeating "ding" sound. This laptop is used as a desktop so the display is always shut and an monitor is connected to it. It hasn't been taken out in ages.
I have an external Bluetooth keyboard connected so I thought that was the issue but the issue persists even when the keyboard is disconnected. Firmly tapping the MBP space bar temporarily stops it but the problem seems to resurface again down the line spontaneously without the space bar even being pressed.
I have tried creating a second user account and logging out while the issue is active but then get a bunch of dots on the password field and the dinging sound (again).
I am thinking this is going to require a replacement of the top case. Or would replacing the keyboard be the better/cheaper route? Any suggestions?
5 commentaires
Dan, I don't think that a spring jumping out of its slot is the issue. The space bar is flush with all the other keys and pops back up after it is pressed. There is no evidence that it is stuck. It's almost as if the space bar is not being pressed at all. I rarely use the MBP's keyboard as well. This leads me to the conclusion the keyboard may have inexplicably gone bad.
par Yuuk
I have the same problem. While watching a YT-video this repeting thing starts out of the blue. Disconnecting mouse and keyboard doesn't help. At the end I have to switch of with the pn/off bottom because opening any menu whil close immediately again. Still no fix.
par Florian
maybe this is more basic PS2Controller kext problem ..
did you try to do updates?
par Jamba
Keyboard and mouse are wireless. I don't see how a PS2Controller can be the issue? There isn't even a PS2Controller-entry in the hardware or software configuration
par Florian
I was playing a game on my MacBook Pro when the 0 key started repeating madly. That key isn't used in the game,and rarely in general. Since then I've noticed it will randomly insert a 0. I thought it might be heat related - it doesn't do a good job of heat management at the best of times. Given the shaky reputation of these keyboards, I have to decide if it's worth using this keyboard at all.
par John Matthias
