Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Magic Mouse est une souris multi-touch fabriquée et vendue par Apple. Elle a été annoncée et vendue pour la première fois le 20 octobre 2009.
Is an inactive Magic Mouse repairable?
Yesterday my Magic Mouse stopped working. I tried several new batteries and it still won't work. Can it be repaired?
Répondu ! Afficher la réponse J'ai le même problème
Indice 15
5 commentaires
When you turn it the mouse on does the green LED light up just above the on/off switch on the bottom.
par Partager
There is no green light. I've tried 10 different sets of new batteries.
par Partager
yes i even bought a new pack of nimh aa s but the pencil eraser was the solution.the contacts looked clean, but....thanks
par Partager
perfect!!! 3 times using pencil eraser
par Partager
cleaned the positive contacts as suggested - problem solved. Thank you!
par Partager
Ajouter un commentaire
4 Réponses
Solution retenue
Thats a good sign ;-}
Try using a pencil eraser to clean the corrosion and/or non conductive film that has built up on the contacts.
A cotton swab slightly moist with white vinegar can also clean up any crust from your alkaline batteries. Be sure to wipe down the area afterwards with some cotton swabs moistened with straight water (not to wet) to clean off the vinegar afterwards.
Indice 25
20 commentaires:
Ta Da! Fixed it with the pencil eraser. Once I read the suggestion I looked, and could clearly see crud on the lower left terminal. Scrub scrub scrub - got my mouse back. Would never have thought that it could get like that, but it did. Thanks.
par Partager
Worked a treat!! Thx
par Partager
It worked (toothpick) !!
Thanks
par Partager
I had to clean the contacts several times with a cue tip and then an eraser ..three times with the eraser .. and then it finally worked. Don't give up !
par Partager
Brilliant and correct. Fixed mine with the pencil eraser. It was cruddy.
par Partager
Voir 15 commentaires en plus
Changing from duracell batteries to energizer is the only difference in making the mouse I have work again.
Indice 0
1 commentaire:
I also discovered that I have some batteries with non-standard plus terminal heights. If the plus terminal heights are too short, they won’t work with the Magic Mouse.
par Partager
I thought I'd post here for once, because my experience was different... I tried all the cleaning tricks after all the other battery troubleshooting, and still no green light. At all. Just quit, went dormant or something. I decided to delete the mouse from my Windows o/s, and just put the mouse aside; kind of clicked it and checked the light several times a day, nothing. Then, three DAYS later, I checked again and the green light came on, once. Baffled, I decided to re-pair to my o/s, clicked and clicked, and voila! It started working again. Perfectly. Perhaps it just needed a vacation! It's a very heavily used mouse, first generation Magic Mouse. Baffling.
Indice 0
If you use a nail file gently it should work. Make sure the contact point is smooth and cleaned off. I used the cotton swab at first with alcohol and it didn’t work.
Indice -1
3 commentaires:
I used 600 grit sandpaper and took my time. I had previously tried a pencil eraser (which is a known fix for cleaning the contacts of electronics) but it did t work this time.
par Partager
Best not to use either as both can be a bit aggressive and can leave metal filings which could make things worse.
par Partager
@danj Heh I'd try it if all else failed. Nothing to lose at that point.
par Partager
Ajouter une réponse
Mark Stone sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 68
Total : 22,968
