I dropped PlayStation vita in water
It is now completely dead. The power button flashes 3 times orange when I plug in charger and that is all.
Robert Furnell, the very first thing you want to do is to stop trying to charge it or use it. Remove the battery and use this guide to disassemble your Vita. Then clean every part with 90%+ isopropyl alcohol and a small soft brush. Repeat this step a few times to make sure that you remove all debris and water. You can submerge the logicboard in the isopropyl alcohol. Check for any burned, charred, or missing components. Once properly cleaned. Leave it dry for a short time. Isopropyl alcohol in this concentration evaporates quickly. Do not use a hairdryer or fan since this can spread any residual debris.water under any IC and may cause further corrosion. Once it is properly cleaned, replace the battery and re-evaluate. Water damage is the hardest to diagnose and the hardest to repair since you never know which parts were affected. Hope this helps, good luck.
great way to down grade if you accidentally upgraded to 3.69 and to download henkaku
I hope this works because my ps vit has been dropped into water it started to work and then boom off so plz hope this works
lets say you got it wet and followed a video opened it put it in dried rice what could happen
Hi, These two links may be of interest. Rice may be good to eat but it does nothing to fix the problems caused by corrosive effects of a combination of liquids and electrical current on electronics
Don't Put Your Device in Rice. Here's Why...
This one explains the better way of fixing the problem of electronics and water damage.
Hope it worked because my sister put mine in the toliet
I suggest you call sony and pay the out of warranty cost
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 36
Total : 13,807
5 commentaires
So we got pet fish and my sister poured water in the fish tank and their was still water in the gage she let it go then all my ps vita got all wet it was working then it went crazy and turned off then i trided to charge but it didn't do nothing
par Miguel
I was playing with water balloons and I made a big one and I went inside with my water balloon and i sat down and it exploded and all the water fell on it so I cleaned and when I saw it and it was wet and I cleaned it and I turned it on and I tried my games and none of the playing bottons worked only the power,home,and volume botton worked
par Edgar mancia duenas
Well I was running by a pond and my psvita fell in and I dove in to get it the light turned on and I soon as I reached at it the light went off and it was dark outside and we couldn't get it that night so we are going back tomorrow to find it I know it won't work but atleast we tried it didn't help that it was 20 degrees tonight
par Taylor freeman
I lost my ps vita and I was looking for it the and I found it in a river so it is not powering complete
par hauwee
My psvita fell in the bath tube because my little sister pushed it it’s been off for a long time plus I never use it any more by off I mean never Ben used at all didint Evan try because it fell in a tube of water I never let her touch my stuff never because. I never trust her she can’t do any thing hope u have any advice puls if u have PlayStation network add me user name is wolfy gameing icon is black cat
par wolfy gaming
