Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Intel Core i5 bicœur avec 3 Mo de mémoire cache L3 de 1,8 GHz
Will a battery replacement fix my MacBook Air
I have a MacBook Air with liquid spilled through the keyboard. The system seems to run fine as long as it's plugged in. The system is unresponsive on battery power alone and the battery reports "Needs Replacement" and shows a constant 15% charge.
A hardware test shows a failure of "4BAT/1/40000000 0x898f3790"
Will a new battery fix this problem? Or does it need a new logic board?
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire:
Hi
I would like to hear to what solution you have got.
Got a similar Problem. Waterdamage is about 2years ago. Mac only running with power supply. Its lagging like !&&*. The SSD passed the test and i got the same Hardware Error like yours. Would like to know what you have done to get it to work
par
Ajouter un commentaire
1 Réponse
What kind of liquid was spilled? Unplug and power off the machine, the longer it is running, the higher chance of a short circuit and more damage. Use this guide to disassemble your machine. Using 90%+ isopropyl alcohol, you are going to wipe down all of the major components and connectors. Immerse the logic board in the alcohol for about 3 hours. Then, take all of the parts and set them in front of a fan to dry. Leave them for 24 hours, or longer if the need more time to dry. Then, once you are sure that they are all thoroughly dry, reassemble the laptop. Try to turn it on with the battery only, then with the power cord only (disconnect the battery). Once you reach this point we can troubleshoot further. Best of luck!
Indice 0
1 commentaire:
It was a diet coke and my dad spilled it about 6 months ago. We thought the machine was dead until we plugged it in a couple of days ago. We'll try your suggestions and report back. Thanks!
par
Ajouter une réponse
steven sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 60
Total : 1,879
