Sorry, i did not take any pictures while taking it apart. But, let me see if i can remember.
First take out the 4 screws that you can see. Next i believe i used a small flat head screw driver and pried around the plastic part where the button is. Now when you do this it will probably brake the plastic clips but thats ok, i used a dab of super glue to keep them together after testing and putting back together. After you get in you are on your own, i forgot at this point what i did exactly.
Just use a toothbrush and alcohol and try and clean the corrosion from the water the best you can. If you get stuck send me a pic and i can see if it helps me remember what i did.
Good luck!
A voté
Annuler
Indice
6 commentaires
I went into the pool also with my Fitbit and it is reacting the same way!!!!! This is a great question that many people ask.
par Genesis
If you end up getting a replacement from fitbit I would be happy to buy your old one.
par Seth McMichael
shoot... happened to me as well.. is there any answer regarding this issue?
par adamaidilpadali
Hi @adamaidilpadli.
You could try using the ifixit battery replacement guide to open the watch, disconnect the battery and then clean away as much of the water as possible using Isopropyl Alcohol 90%+ and a soft toothbrush. Be gentle when doing this. When finished allow it to fully dry. Shouldn't take long to dry as is alcohol. Then re-assemble and don't forget to reconnect the battery. Good luck with the repair.
Take pictures before disconnecting /removing anything as an aid to re-assembly in case you forget which way it was etc.
Remplacement de la batterie du Fitbit Charge HR
par jayeff
Same problem here. Second Fitbit this has happened to.
par Laurie Lewis
Afficher 1 commentaire en plus
