Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Cafetière à tasse unique noire et argentée avec réservoir d'eau sur le côté gauche. K40/K45.
The water coffee just dribbles out
I cleaned my brewer with white vinegar and used the paperclip trick. The water comes out nicely when there is no K-Cup or if I use the cup that you put your own coffee in. When I use a K-Cup, the water coffee just dribbles out. It's got to be related to that tube and how the coffee exits the basket when the K-Cup is in there, but I just can't figure out what the problem is...
Répondu ! Afficher la réponse J'ai le même problème
Indice 19
10 commentaires
Dump the Kuerig and buy a different coffee maker.. Ive had 3 Kuerigs and they all quit. Waste of money...Im done with Kuerig.
par
IMO most owners just use their Keurig everyday until it quits working properly. Keurigs need maintenance more than other coffee makers. You need to clean the head with a paper clip occasionally, run a brew without a k-cup (will help keep coffee grounds out of your cup) and clean Keurig with vinegar every 2 months. My first Keurig was a B70 that I purchased at Goodwill for $5.99. I now have a Keurig K575 with Carafe, I can use any k-cup and have all menu options using a special clip purchased at Amazon.
I purchase Keurigs at Goodwill and get them working properly and have given 6 Keurigs to family members and 2 to friends. I love Keurigs!!!!
par
What special clip
par
@donna wilborne - Full Menu Clip, Metal Freedom Clip by Geesta on Amazon $10.99. You receive 2 metal clips 2 orange tabs plus extra orange stickers, You just snap (1) clip on and install (1) orange tab. The cost will be recouped quickly because you can use any k cup or use a refillable. You will no longer get the "Oops Message".
par
@Dan Taylor - I was not aware of those clips. I use the My K-Cup, which also unlocks the full menu, but, I use my own coffee. I'll look into the clip, though. Thanks!
par
Voir 5 commentaires en plus
Ajouter un commentaire
5 Réponses
Solution retenue
Lyn F, clean both the upper and lower needle valve. See if this guide helps you out
Indice 41
11 commentaires:
Great instruction. I had previous relative success in clearing our K40 with OEM descaling steps plus blowing out the needles with a handheld air canister. When it now developed seemingly incurable enlarged prostrate dribbles, your solution worked like a charm!
par
I made an account just to say thank you!
par
@mattbryant44 thank you for doing that. It is greatly appreciated. Welcome to iFixit.
par
Awesome guide, it helped us get our Keurig back to performing optimally and thus saved many lives at the office! :-)
par
I too created an acct just to says thanks for helping fix my baby! :)
par
Voir 6 commentaires en plus
After conducting all recommended cleaning procedures i still had a very slow drip rate, I found a small piece of plastic in the bottom K-Cup needle punch shaft, ( it was plasic from a K-Cup). It was very difficult to see, I had to remove the K- Cup holder and using a flash light to enhance visability of the punch shaft hole and needle area. I seen a small white piece of plastic in the shaft. I took a sewing needle and carfully removed the piece of plastic K-Cup from the punch shaft. I have had coffee grounds in the upper punch shaft that interfered with proper flow. This was the first time the bottom punch was the guilty party. After removing the debris from the shaft, my 3 year old Keurig 2.0 ran like i just pulled it out of the box. Reading Keurig issues on this site has helped me resolve my problem. I wanted to pass this experience on, in the event it may help others. Coffee grounds and calcium build up are not the only flow obstructions you may come across.
Indice 3
1 commentaire:
No coffee com s out only water and have done ALL STEPS
par
Our three year old Keurig suddenly started to run very slowly and produce only a partial cup of coffee. I tried all of the recommended fixes, even taking the upper check valve out and soaking it in vinegar. Cleaned all the needles and outlets with no success. We bit the bullet and bought a new Keurig and… it ran exactly the same way. I then remembered one person commenting online that there was a problem with her K-cup. I purchased a 12 pack of Green Mountain K-cups, reasoning that since Green Mountain is the parent of Keurig they should know how to make good K-cups. It worked!!! Flow was fast and the quantity of coffee was as expected.
The problem started at the same time we purchased an order of Donut House K-cups online. Same brand that we have used for a couple of years. I believe the paper filter in their K-cups is now more restrictive as there is a large amount of liquid left in the used K-cup. So now we use the same K-cup for two passes on the Keurig. Usually two identical medium size settings work best. Still have to use up over 200 of the faulty Donut House K-cups and when gone no more.
== Problem may be with the K-cup''
Indice 1
2 commentaires:
The worst problem I have is with the New England brand. Always a big mess of grounds
par
The article above solved my issue. I never realized there was an opening in the bottom needle..turns out i had coffee grounds in it. Once I cleaned it out (with a paper clip)_ coffee brewed normally. TY.
par
You can purchase a Keurig needle cleaner. It's a simple process of turning off the Keurig, filling the little pod-sized cleaner with water, inserting it, and then opening and closing the lid at least 5 times to clean the needle. You can also remove the entire pod holder unit, being careful to not touch the needle, and the shovel tray under that. Then just rinse both with water, dry, and replace. There are YouTube videos that show how. It solved the drip I was having after a brew and sped up the brew too.
Indice 0
1 commentaire:
I cleaned the top and bottom needle using a open safety pin and a flashlight to see. The bottom needle had chunks of coffee grounds around underneath a little washer. After cleaning, Yay it's working again .
par
My least favorite thing about my machine was the constant dripping after I removed my cup. My drip tray was always a mess.
I used to use a folded-up napkin or paper towel, but it looked sloppy. Tbh, most of the time I'd just let it get dirty and then hate cleaning the gunk later.
I found these disposable absorbent pads on Amazon and they have been a total game-changer. I just lay one on the drip tray, and it catches everything with a single pad lasting over a week. My machine finally stays clean. Just wanted to share with the community thats been super helpful with other issues I've had :)
Link: https://www.amazon.com/Absorbent-Disposa...
Before
After
Indice 0
Ajouter une réponse
Lyn F sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 87
30 derniers jours : 469
Total : 241,494
