Here’s a quick overview on how to get the button housing out of the case. I got so mad at the prospect of having to buy an entire new rear shell because of one little broken cable that I resolved to find a way. It’s epoxied in, so take a deep breath, find some inner calm and then arm yourself with a heat gun. Remove all the extra stuff anywhere near the button housing (including that little strip of black folds that runs along the bottom of the screen area, held in by five tiny screws). Point the heat gun at the back of the case, just where the button housing sits. Let it heat up real good, and then take a spudger or small flat screwdriver and try prying at the button housing. Be patient, it took me about ten minutes of heating and poking to get it out. But it is do-able, and when you get it, you will attain a deep and magnificent joy. When putting it back, use hot glue to make life easier for anyone who might have to get it out again.
Cette réponse a-t-elle été utile ?
A voté
Annuler
Indice
8
My power button cable was also damaged while adding an SSD to my iMac. The conector that connects to the logic board to be more precise. Is there anything that can be done to fix this issue?
par Andrew Posani
@Andrew - Do you still have the connector end or is it broken?
par Dan
It's broken. I don't even know where it went. I got the logic board reseated and looked up and it was broken.
par Andrew Posani
To update my situation, I fixed my problem by cutting the wires off the old power button, purchasing a rear housing off eBay and splicing the wires together with the connector from the purchased housing. Everything works great and my computer now has 2 new hard drives. Thanks for the help and answers!
par Andrew Posani
It's possible to take off the power button ?
par didier
Voir 6 commentaires en plus
